python 991 door locks
moro365
Posted: April 11, 2010 at 4:47 PM / IP Logged
adding door locks to jeep wrangler with python 991 it will lock but wont unlock used the wireing diagram on the web site for a 5 wire and still wont work please help!!!
tedmond
Gold - Posts: 4,610
Posted: April 11, 2010 at 4:54 PM / IP Logged
time to probe the output comming from the 991 and see if its dead or not.
Ted
Compustar Expert
t&t tech
Platinum - Posts: 2,622
Posted: April 11, 2010 at 4:56 PM / IP Logged
Also have you verified you have the correct motor wire?
moro365
Posted: April 11, 2010 at 5:19 PM / IP Logged
i did probe it and the lock side goes from 12v to 0v when i hit lock and it works but when i hit unlock and probe the unlock side it stays at 12v is there a seting on the 991 that needs to be changed??.....and yea i have the right motor wire
t&t tech
Posted: April 11, 2010 at 6:03 PM / IP Logged
You have a rest at twelve system! Are you sure?
Something is wrong with the unlock relay or the wiring!
moro365
Posted: April 12, 2010 at 11:23 AM / IP Logged
im sorry i ment when i hit lock the lock wire from the 991 says -500ma and when i hit un lock the unlock wire coming from the 991 doesnt change its like the 991 isnt sending the signal to the unlock relay???? could there be a setting on the 991 or somthing???
Posted: April 12, 2010 at 11:37 AM / IP Logged
Not sure, what's a Python but snaking around, my thoughts are that baby has a two wire locking system, thus a 451 or a pair of relays needed. But wait....what year is this beast? Early models, 92-5 used pos triggers on the factory relays, hence 5 wire not required. Later variants used a resistive multiplex trigger. So can we have some testing please?
moro365
Posted: April 12, 2010 at 11:43 AM / IP Logged
its a 2000 but it doesnt have factory door locks so im using dei's 524n lock actuators
t&t tech
Posted: April 12, 2010 at 4:50 PM / IP Logged
Nope no setting could affect that! A simple test, momentarily ground the trigger of the relay where unlock wire is connected if the locks pop, then you have a defective unit!
Posted: April 12, 2010 at 4:55 PM / IP Logged
Right Darren, you get the cigar this time, now go over to the Vehicle info section, look at Toyota Yaris/Fun cargo and see why my blood pressure's gone up the charts. The guy is in the Windies so maybe you can have a go.
