new here with a problem with bmw
Posted: April 16, 2010 at 4:25 PM / IP Logged
A motor wire normally sits on ground and goes pos. Your biggest problem is that you don't know what you're doing. Go for the triggers. Have you identified them? What colours are they. You are messing this up, I don't know of any 2 wire alarm lock wires that are normally pos.
cemz
Member - Posts: 10
Posted: April 16, 2010 at 4:54 PM / IP Logged
Ok, let me try to make this clear cause I'm getting more confused when I'm reading your replies lol.
Alarm Module
GREEN / WHITE = Lock (-)
Blue/white = Unlock (-)
Green = Door Trigger (-) which I've already wired to my door switch. Works fine.
Factory Alarm Prewired harness
WHITE/ red = Lock (+)
Blue/gray = Unlock (+)
This is the 12 pin Factory Alarm prewired harness layout
Locking Tab
1...2...3...4...5...6
7...8...9.10.11.12
Pin#.............Function......................... ........Wire Color
1...........Constant 12VDC....................RED / Green or RED / Gray
2...........Ignition 12VDC.......................Violet/White
3...........Chassis Ground......................BROWN / Orange or Brown
4...........(-) Driver Door Trigger............BROWN / Gray
5...........(-) Passenger Door.................BROWN / Blue
6...........(-) Rear Door...........................BROWN / Black or BROWN / Violet
7...........(+) Horn Trigger......................BLACK/ Blue
8 Not Used
9...........(+) Lock...................................WHITE/ Red
10..........(+) Unlock................................Blue/Red or Blue/Brown
11..........(-) Trunk Trigger......................BROWN / White or WHITE/ Brown
12 Not Used
Posted: April 17, 2010 at 1:56 AM / IP Logged
OK, thanks for that last post, I think we're getting somewhere now.
I apologise for the confusion but since I've never seen the US version I was going on Bulldog and Directechs which stated that although the locking system used pos pulses, the factory alarm plug used neg!.
Of the relay diagrammes you originally posted,the first one is correct BUT turn the left relay around so that the neg pulse from your module goes to 85. Then place a diode* across 85 and 86 on each relay with the band towards the pos side to protect your unit.
Now here's the clever bit. does your unit have a timed aux output?
If so set it for 10 secs., or 15 if you have an electric sunroof and run it to 85 on the lock relay. Every time you press that aux, it will deadlock the car and close the windows/roof.
*1N4004 diodes.
cemz
Member - Posts: 10
Posted: April 17, 2010 at 9:45 AM / IP Logged
Thanks for the advice, and I'm glad were on the same page now lol. Would you make a diagram of how the wiring should be? So when I do get started on this again, I won't have to think real hard on it when I shouldn't.
Posted: April 17, 2010 at 10:05 AM / IP Logged
Relay 1 Lock Alarm lock wire to 85
12V+Constant fused at 3amps to 86 and 87
Output to car's lock trigger wire (WHITE/ red) from 30
If you have an aux on your alarm that you can set up as timed, feed it to 85 on that relay. It should close the windows/roof.
relay 2 unlock.
alarm unlock wire to 85
Same fused line as above (shared) to 86 and 87
Output to car's unlock trigger (blue/red) from 30
Don't forget to diode across the coil, band of diode towards the + side (86).
If there's a remote start involved, let me know because you will need to know some BMW specific details that aren't in any guides!
cemz
Member - Posts: 10
Posted: April 17, 2010 at 10:35 AM / IP Logged
I appreciate it!! Actually my alarm does have a timed aux output. What is all required for it, cause the package did not come with any extra hardware. And how would you install this?
Sp-100
      2-Way FM/FM Combo Alarm, Keyless Entry and Remote Start System
      2-Way FM/FM Touch Screen Paging Remote with Fully Animated LCD Graphics and Audible Tones for Confirmation of Alarm Status, Violation and Engine Start
      Includes Sidekick Non-Paging Remote
      Dynamic Code Protection (Anti Code-Grabbing)
      Code Learning Receiver
      Electronic Dual-Stage Shock Protection (Plug-In Design)
      Multi-Zone Trigger Protection
      Defective Zone Bypass with Warning Chirps
      Alarm Pre-Warning Signal
      Manual Arming Mode: Allows you to arm/disarm the system without carrying a remote control
      On-Board Relay for Flashing Lights
      Audible and Visual Arm/Disarm with Intrusion Alert
      Programmable Carjack Protection
      Programmable Vehicle Horn Output
      Remote Panic Protection
      25W High-Power Mini Single Tone Siren
      Passive Door Locks (Programmable)
      Passive & Active Re-Arming Mode (Programmable)
      LED Diagnostic for Last Zone Triggered
      Remote Keyless Entry
      Built-In Door Lock Relays
      Dual Parking Light Relays (+) or (-)
      Auto Lock/Unlock Through Vehicle's Ignition
      Separate Driver's Door Unlock Priority
      Double Unlock Pulse (Programmable Feature for Factory Interface)
      1 or 3 Second Door Lock Pulse (Programmable)
      Silent Arm/Disarm Through the Remote
      (6) Programmable Remote Auxiliary Outputs: Momentary, Timed or Latched
      (4) Vehicle Operation
      Dome Light Illumination
      Programmable Arm/Disarm Chirps
      Transferable Limited Lifetime Warranty
      86 Programmable Options
Remote Start Features
      Turbo Timer Mode: Allows Engine to Continue Running from 1-5 Minutes After Key Removal
      "Ultra Smart" Tachless Mode
      Programmable "Wake Up" Ignition Pulse on Unlock for Vehicles with "Slam Locks"
      Timed Crank Mode (Pre-set Starter Cranking time in 4 Increments of 0.5-1.5 Seconds)
      Glow Plug Input or Programmable Timed Delay for Diesel Engines
      (5) On-Board Remote Start Relays for Easy Installation: ACC, IGN, IGN2, Start, and Parking Lights
      Selectable Engine Speed Sensing: "Smart" Tachless or Tach (RPM) Learning
      Remote Start Diagnostics
      3rd Start Output
      Tach Finder Mode
      Timed Start Mode
      Idle Down Mode
      Programmable Engine Run Time: 3min, 10min, 15min or 20min
      Factory OEM Alarm Arm/Disarm Outputs
      Negative Ignition Output for Additional Relays or Anti-Theft Bypass Modules
      Hood Open Safety Circuit: Unit will not Remote Start if Hood is Open or Ajar
      Foot Brake or Parking Brake Option
Remote Features
      2-Way FM/FM Touch Screen Pager with Fully Animated, Color 3D LCD Graphics and Voice Confirmation of Alarm Status, Violation, and Remote Engine Starting
      Rechargeable Internal battery
      Range Meter
      Vehicle Battery Voltage Check Meter
      Vehicle Temperature Check Meter
      Parking Meter Timer
      Alarm Clock
      Daily Timed Start
      Trigger Record (Check the Time and Date of the Last 4 Alarm Triggers or Violations)
      Pin Code Set: Remote will not unlock the doors unless the proper code has been entered into the remote (Programmable)
      Alarm Status Check
      Real Time LCD Clock
      Backlight Adjustment: Bright, Dark, Etc
      English or Spanish Language Settings
      Silent Arm/Disarm
      Arm Without Shock Sensor
      Car Finder Mode
      Button Lock Protection: Buttons can be Locked to Prevent Accidental Pressing
      Power Save Mode
cemz
Member - Posts: 10
Posted: April 17, 2010 at 10:37 AM / IP Logged
Opps sorry thats the wrong one, I was looking at the wrong alarm lol. It seems that my alarm doesn't have the timed aux output. Sorry about that.
Posted: April 17, 2010 at 12:44 PM / IP Logged
Does it have any aux outputs? I'm about 3500 miles away over the pond and I'm not familiar with the brand! Two answers:
1) Take an existing aux and run it through a DEI 528t set to the right time, run a parallel wire off your lock wire through a relay to interlock it with your ignition, i.e wire from lock side to relay 30, relay 87a to 528t, ignition to 86 and ground to 85. Run a wire to the unlock side from this wire, place a 1N4004 diode inline on that wire with the band towards the unlock side.This means that if you lock the doors when ignition is on, either manually or auto lock it wont close the windows or deadlock but if you arm the device it will automatically close the windows and deadlock the car. Post me if you want the remote start info.
