Mitsubishi Pajero NM GDI V6 3500
nracer
Posted: April 13, 2003 at 9:47 PM / IP Logged
Searched all over and no one here at my place has a clue. Problems :-
1. Could not locate the power door lock/unlock wires. I traced the 5-wire-factory 'actuator', able to detect one ground, and the other 4 in pairs, only shows 12V neg and 2-3V neg when manually lock/unlock. How do I tap onto the central locking? I'm a newbie at this.
Pls advise.
Allan
draasch
Gold - Posts: 2,172
Posted: April 13, 2003 at 9:52 PM / IP Logged
does the driver door control all of the doors????
if so you can add a ACTUATOR to the drivers door and hook it up to the alarm. it will inturn operate the rest of the doors.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: April 13, 2003 at 10:03 PM / IP Logged
Here is what I have for the 1999 Mit Pajero :
|          STARTER|BLACK / YELLOW        |   |ignition harness            |
|         IGNITION|BLACK/ white         |   |ignition harness            |
|       POWER LOCK|BLACK/ red           |-  |module under o/side dash    |
|     POWER UNLOCK|BLACK / YELLOW        |-  |module under o/side dash    |
| PARKING LIGHTS +|gry/red & gry/yel   |   |at switch                   |
|       HEADLIGHTS|RED / yellow          |-  |headlight switch            |
|     DOOR TRIGGER|GREEN/ red           |-  |blk plug behind speedo      |
|       TACHOMETER|WHITE/ blue          |   |wht plug behind rev counter |
|       BRAKE WIRE|green               |   |brake pedal switch          |
nracer
Posted: April 13, 2003 at 11:05 PM / IP Logged
don't be able to locate this wire but opening the driver's door panel reveal that it is a 5 wire factory actuator operated via cable from the opener. Saw the bk/red n bk/yell but it is hooked on to the door light.
Installing an actuator need some creativity I guess and space limitation by the window glass.
Pls help.
The nearest installer is about 500kms away and have not done on this vehicle too. :(
nracer
Posted: April 14, 2003 at 12:12 AM / IP Logged
or can i cut two wires that power the lock/unlock mechanism and power them separately from the alarm?
Posted: April 14, 2003 at 8:07 AM / IP Logged
Have you tested the two wires listed with a light tester or DMM to see if they are the target wires ?
nracer
Posted: April 14, 2003 at 7:45 PM / IP Logged
I'm not sure I'm right, this is what I've done so far. Out of the five cables, one is black - common ground. The rest four wires are in pairs ( I believe) as they share one common colour and of different gauge. The thicker ones when probe individually shows 12V when I turn the door key lock to lock/unlock respectively. The other thinner wires show lower voltages....
I thought about it through the night, my options are :-
1) cut off the two thicker wires 12V and wired them to seperate relays to lock/unlock. But will I loose the central locking functionality? Only one way to find out right? Cut n join them back should it went wrong?
2) trace the trigger wire and perhaps add diodes in order to protect the original circuit?
kindly help me step-by-step in troubleshoot my first attempt...
nracer
Posted: April 14, 2003 at 7:53 PM / IP Logged
or third option as highlighted by most installer, add an actuator. Is that a wise solution? I find it difficult to add as the metal pin is on the outer side which means I need to install the actuator on the outer side after the window glass right? How can I secure it then? Arghhh...  desperately needing help
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
