remote start using factory remote
Ynot80
Member - Posts: 33
Posted: June 17, 2010 at 9:54 AM / IP Logged
Ive seen cars come in with aftermarket remotes starts hooked up so that if you hit the lock button on the factory remote 3 times the car starts . Oddly enough Ive never had to do this but Im interested in knowing how its done . We use 2 different units at the dealership I work for ( AM6.2 and the AM 6) . Would I be able to hook either one of those units up using the factory remote and if so what would I need to do different over a normal install ?
Mark Mizenko
Copper - Posts: 460
Posted: June 17, 2010 at 12:32 PM / IP Logged
WHITE/ Blue (activation input) wire to the lock switch or motor wire wire, and program it for 3 pulses.
It should be in the Automate install manual.
Ynot80
Member - Posts: 33
Posted: June 17, 2010 at 2:33 PM / IP Logged
So Id just have to wire the wht/blue with the green lock wire to the lock wire of the car and program it and its all good. I was reading the install manual and I thought thats all Id have to do but wasnt sure.
chev104275
Gold - Posts: 1,436
Posted: June 17, 2010 at 5:38 PM / IP Logged
if using the switch wire make sure it gets pulsed when you use the factory remote to activate the locks.    I usually use the lock motor wire with a relay to reverse the polarity to negitive then go to the WHITE/ blue of the starter with the output of the relay
Ynot80
Member - Posts: 33
Posted: June 17, 2010 at 11:33 PM / IP Logged
Just to make sure I got this straight if I want to use a relay Id put ground on 85 and 87,lock motor wire on 30 and the WHITE/ blue on 86 . Also is there a setting to change to make the WHITE/ blue wire pulsed ?
Platinum - Posts: 13,725
Posted: June 18, 2010 at 4:32 AM / IP Logged
Before you get all into the job, you need to make sure the factory keyless will unlock the door when the motor is running.  Start the car with the key, with the key in the ignition, and motor running try to lock and unlock the doors with the factory keyfob.  If the car will not unlock or lock with the motor running, you will have to unlock with the key to enter the vehicle, and you will not be able to hit Lock, lock, lock to end the remote start session.
Ynot80
Member - Posts: 33
Posted: June 18, 2010 at 6:18 AM / IP Logged
Yeah I know that. Right now I dont have a need to do something like this Im just trying to get more info so that if it comes up in the future I'll know . Lately Ive been doing a lot of new Hondas so trying to do something like this isnt going to work cause the factory remotes dont work when the car is running . Every so often I get in a used car something that I could do this on .
Posted: June 18, 2010 at 6:50 AM / IP Logged
It is still possible on some of the vehicles.  Some vehicles have a separate keyless module that has an ignition feed.  You can cut the ignition feed so it will not know that the vehicle is running.  Some of the keyless systems are integrated in the BCM, those are not so easy to get around.
Ynot80
Member - Posts: 33
Posted: June 18, 2010 at 6:57 AM / IP Logged
Cool. Ill keep that in mind too . Any of the hondas I do the customer is just told that they have to have a seperate remote. So far no one has complained . Like I said for some odd reason Ive never had to install a remote start using the factory remote and I was just wondering if how I thought it was done was right .
itsyuk
Silver - Posts: 505
Posted: June 23, 2010 at 2:07 PM / IP Logged
plus some factory remotes lack the range to make remote start as convenient as an aftermarket remote would.
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
