Autotek XS1500.1 and (3) JL Audio 12W3
DjIQ
Copper - Posts: 107
Posted: April 15, 2003 at 7:02 AM / IP Logged
Can I hook up 3 JL Audio 12W3's to an Autotek Amp (rated 1500 x 1) without destroying the speakers?
bberman1
Gold - Posts: 2,314
Posted: April 15, 2003 at 8:55 AM / IP Logged
They should be able to handle the excess power. How many ohms is each sub?
DjIQ
Copper - Posts: 107
Posted: April 15, 2003 at 11:56 AM / IP Logged
4Ohm DVC
bberman1
Gold - Posts: 2,314
Posted: April 16, 2003 at 11:57 AM / IP Logged
But the most power you can get safely out of the amp will be @ 2.5 ohms http://www.audiobahninc.com/tech/wiring/Series_Parallel_dual_4_ohm.pdf with (3) 4 ohm dvc. You could wire it in parallel but that will give you 0.67 ohms and your amp is not stable that low.
