tach wire
xxunknownxx
Member - Posts: 43
Posted: June 28, 2010 at 7:17 PM / IP Logged
Hi, Im new here my name is Brad.
Ive done some searching on this topic. First of all we have two vehicles in need of a tach wire. My 00' Crown Victoria and my brother's 97' P71 Crown Victoria.
I'm aware that I can tap into the PCM but space is a bit limited and I don't think i can get in there with my soldering iron. But my question is....can I tap into the uncommon wire on the fuel injector.
Wiring diagrams suggest this for the 2003-up models....but I was curious if I could do it on the 2000 model an the 1997 model.
I know I could use the coil on the 1997 model but I would have to extend the wires...I'd rather use the injectors on both cars. Is it possible.
2003 -2004
TACH       Any wire that is NOT RED or RED / LIGHT GREEN       @ IGNITION COIL or FUEL INJECTOR
xxunknownxx
Member - Posts: 43
Posted: June 28, 2010 at 7:18 PM / IP Logged
I dont know if it helps but both of the remote starter units are Avital 4113l.
KPierson
Platinum - Posts: 3,527
Posted: June 28, 2010 at 7:29 PM / IP Logged
You should be able to do that with no issues. Try it out and if you have problems with it use a different tach source.
Kevin Pierson
xxunknownxx
Member - Posts: 43
Posted: June 28, 2010 at 7:33 PM / IP Logged
Awesome. Thanks :)
xxunknownxx
Member - Posts: 43
Posted: June 29, 2010 at 2:52 PM / IP Logged
All went well :) Starts with no problem. Programmed on the first try and no overcrank or undercrank.
Now its time to tackle the malibu....that normally takes 3 seconds to start. Theres no way tachless would work for this car.
Ive tried everything to fix the hard starting issue. New starter new flywheel. Car runs perfect so i gave up lol :)
tedmond
Gold - Posts: 4,610
Posted: June 29, 2010 at 5:36 PM / IP Logged
depending on the year of the malibu. some use mux or multiplexed systems, and it will never grind or fail a start.
Ted
Compustar Expert
edoubled
Posted: July 01, 2010 at 1:57 PM / IP Logged
If i remember correctly the rule of thumb is always Ford go to a fuel injector, Chrysler go to a coil.  Ive had issues before with Ford cars not cold starting in the winter very well with a coil tapped in so fuel injector was the best way to go.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
