2006 toyota tundra wiring
tydbol611
Posted: July 18, 2010 at 7:49 AM / IP Logged
Hello can someone please help I brought a double din dvd player for a 06 toyota tundra and bought the wrong harness tried to wire it anyway, i cut the original harness and tried hardwiring but dont know all of the wire colors and what wire goes to what, ionly have most of the speaker wires,ground. please help. let me know what i need iam thinking i have to replace the original harness and get the right harness for the unit i have. thanks in advance.
Platinum - Posts: 13,673
Posted: July 18, 2010 at 9:23 AM / IP Logged
Does the Radio or any of the speakers have a JBL logo printed on them?
Posted: July 18, 2010 at 9:26 AM / IP Logged
When you cut the harness, did you have the key turned on and cut all the wires at the same time?  If so you have 2 blown fuses in the fuse box.  You did not mention that you had located either of the 2 power wires.
tydbol611
Posted: July 18, 2010 at 3:20 PM / IP Logged
i believe the two power wires are red with green strip and gray
i cut the wires withe cut off
tydbol611
Posted: July 18, 2010 at 3:24 PM / IP Logged
no its not a JBL
Posted: July 18, 2010 at 5:45 PM / IP Logged
2006 toyota tundra wiring - Last Post -- posted image. Battery BLUE / YELLOW (+) RADIO HARNESS 2006 toyota tundra wiring - Last Post -- posted image.
2006 toyota tundra wiring - Last Post -- posted image. Accesory GRAY (+) RADIO HARNESS
2006 toyota tundra wiring - Last Post -- posted image. Ground BROWN (-) RADIO HARNESS
2006 toyota tundra wiring - Last Post -- posted image. Illumination GREEN (+) RADIO HARNESS
2006 toyota tundra wiring - Last Post -- posted image. Amp Turn On PINK/BLUE (+) RADIO HARNESS
2006 toyota tundra wiring - Last Post -- posted image. LF Speaker (+) PINK
2006 toyota tundra wiring - Last Post -- posted image. LF Speaker (-) VIOLET
2006 toyota tundra wiring - Last Post -- posted image. RF Speaker (+) GREEN
2006 toyota tundra wiring - Last Post -- posted image. RF Speaker (-) BLUE
2006 toyota tundra wiring - Last Post -- posted image. LR Speaker (+) BLACK
2006 toyota tundra wiring - Last Post -- posted image. LR Speaker (-) YELLOW
2006 toyota tundra wiring - Last Post -- posted image. RR Speaker (+) RED
2006 toyota tundra wiring - Last Post -- posted image. RR Speaker (-) WHITE
The Note for the battery wire does read (RED)
tydbol611
Posted: July 18, 2010 at 6:24 PM / IP Logged
thanks but my harness doesnt show  some of those colors like battery blue/ yellow only blue for green illumination which green i remove a 20pin thats the largest and another 20 pin thats smaller also its another harness i didnt cut which wires are need iam sorry to be so ignorant to this but its my first time doing this. thanks in advance.
