Door Lock Actulator Rod
JaysOnTheEdge
Member - Posts: 10
Posted: April 16, 2003 at 8:32 PM / IP Logged
Does anybody know where i can buy just the Door lock actulator Rods themselves and is it possible to use a 5 wire actulator as a 2 wire actulator.  I messed up my actualtor install and i found a diagram of how ford has it mounted oem so i want new rods to i can bend them and mount how hey have it.  and the install shop i went to said he could use my 5 wire actulators as 2 wire. Is this possible.  i have a commando 5 wire central locking system if that helps.
Platinum - Posts: 12,488
Posted: April 17, 2003 at 1:06 AM / IP Logged
Go to your local bike shop and ask for some  DT Spokes, they are the same thing but longer.
sbourg
Member - Posts: 8
Posted: April 17, 2003 at 8:41 AM / IP Logged
5-wire actuators have three wires to an internal switch to use in triggering the system - the other two wires go only to the motor. If you don't want to use the switch, leave those three disconnected.
Steve
sbourg
Member - Posts: 8
Posted: April 17, 2003 at 8:48 AM / IP Logged
Steve
cpgoose
Gold - Posts: 1,098
Posted: April 17, 2003 at 10:41 AM / IP Logged
along with your local bike shop like Jeff suggested, you could also probably try a local alarm/stereo shop. I'm sure they'll have some laying around for a $1.00.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
