nissan sunny 96 alarm wiring
hellsborne
Posted: August 06, 2010 at 4:03 PM / IP Logged
i need the wire colours and locations of the wires you need to insatall an alarm in a 1996 nissan sunny super saloon
Platinum - Posts: 7,828
Posted: August 06, 2010 at 4:48 PM / IP Logged
I think a Nissan Sunny is a righthand drive Nissan Sentra.  T & T can probably help you.
Here is a link to Bulldog Security where you can look up the Sentra and see if it's the same.  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
t&t tech
Platinum - Posts: 2,622
Posted: August 06, 2010 at 7:02 PM / IP Logged
1996, of the top of my head,
Starter - black white
ignition- BLACK/ red
12 volts - either white or red i think
Park lights - blue (Driver kick)
Door trigger - RED / white (driver kick)
Power locks -  That year's sentra has the power locking module built into the driver door controls you can do all you wiring in the door! you can do it either of two ways one is the aftermarket actuator wired for reverse polarity, since that car has central locking! Or you could interrupt the motor wires and wire it basically the same as the aftermarket setup with a few differences, the neat thing about the second method is if your speed locking still works, it will control all doors, which is totally cool! LOL, I know i have a 1996 sentra, since i was a kid i loved that car and thought i had to own one someday! nissan sunny 96 alarm wiring -- posted image.
t&t tech
Posted: August 06, 2010 at 7:05 PM / IP Logged
Like the configuration above, the switch, when moved in either direction, applies both power and ground directly to motor legs  without the use of any relays. Except, at the switch in this case, both motor legs rest at ground . Therefore it is only necessary to change the polarity of one motor leg to lock or unlock the vehicle.
nissan sunny 96 alarm wiring -- posted image. Actuators / Reverse Polarity
This is practically identical to the 5 wire alternating 12V(+) system above. The only difference is there's no switch! Both motor legs rest at ground at the relays. To lock or unlock the vehicle, polarity is changed on one motor leg.
t&t tech
Posted: August 06, 2010 at 7:07 PM / IP Logged
Ignore the text and follow the diagrams, follow the first diagram! Lemme know if you need help!
Posted: August 07, 2010 at 2:28 AM / IP Logged
Assuming UK spec, around that time they also used a 1 wire ground and open circuit to control the locks, if there's lock relay mounted vertically to the side of the steering column, also direction indicators, not lights and door triggers.
Actually a DMM would answer our poster's questions.
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
