cubic feet 8 jl w3 sub fiber glass enlc
antwone230
Member - Posts: 8
Posted: October 13, 2010 at 1:30 AM / IP Logged
I am making a custom fiber glass enclosure for my 8 inch JL audio W3 and I am not sure on how much air space this sub needs to be on the inside? I am putting the enclosure in the back right rear of the trunk.
BOOM, All day every day
antwone230
Member - Posts: 8
Posted: October 13, 2010 at 10:03 AM / IP Logged
Alright in a sealed enclosure the volume would be 0.3. Do I have to add the Driver Displacement: which is 0.03 . Do I combine both numbers for my total enclosure internal area?
mrm1776
Copper - Posts: 100
Posted: October 13, 2010 at 12:53 PM / IP Logged
It should be the volume AFTER you've removed the displacement of the woofer. So 0.33 is what you should aim for. This is just going off of the numbers you gave me.
MECP Basic Installation Tech
Certification ID: CEA195600
Pioneer AVIC-X920BT
Polk Audio DXi 6500 - front
Rockford Fosgate Power T1693 - rear
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
icearrow6
Copper - Posts: 497
Posted: October 13, 2010 at 5:19 PM / IP Logged
Also don't forget to take into account the displacement of the woofer itself.
So:
.3 (your goal) = Total Volume - Bracing - woofer volume.
antwone230
Member - Posts: 8
Posted: October 14, 2010 at 1:30 AM / IP Logged
so you mean if the box is 3 cubic feet and then when i put the sub in that subtracts from the 3 cubic feet so i have to compensate for the lost volume?
I am really confused on this box volume and how big i need for it to be.
Alpine Guy
Platinum - Posts: 2,478
Posted: October 14, 2010 at 8:00 AM / IP Logged
You need a .33 cu.ft box to compensate for the driver displacement.
mrm1776
Copper - Posts: 100
Posted: October 14, 2010 at 10:23 AM / IP Logged
Or slightly bigger depending on how much bracing you do. 0.33 is a pretty small box though so you shouldn't have to do a ton of internal bracing.
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
icearrow6
Copper - Posts: 497
Posted: October 14, 2010 at 12:19 PM / IP Logged
Yes:
(woofer displacement) + (internal bracing) + (target net volume) = TOTAL VOLUME your box needs to have.
Example:
.3 Qft (woofer) + .5Qft (bracing) + 3 Qft (desired airspace) = 3.8Qtf (total air space needed)
antwone230
Member - Posts: 8
Posted: October 14, 2010 at 3:24 PM / IP Logged
to make .30 ft............... 12in x 10in x 8in (Width x height x Depth)
305mm x 254 x 203mm
Is this correct guys?
Alpine Guy
Posted: October 14, 2010 at 4:41 PM / IP Logged
305mm x 254 x 203mm
That would be .33 if those measurements are outside measurements, and the enclosure wall thickness is 3/4"
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
