dpdt relay harness where to source?
batook
Member - Posts: 13
Posted: November 08, 2010 at 5:39 PM / IP Logged
I need to wire up a DPDT relay to trigger the lock actuator of my driver's door.  I would prefer to use a nice clean wiring harness that the relay will connect into and provide me with 8 wire leads to work with.  I found a DPDT relay from partsexpress.com that will work for about $6, but I can't find a wiring harness to use with it.  I guess I can just solder my connections directly to the relay and try to tape up the exposed leads as best as I Can, but it worries me that I will have +12V on one of them and it could be somewhat exposed, or the tape could come off, etc.  A harness that connects onto the relay would really be ideal.  Might Checker or Napa have something like this?  Any help or advice on where to source this would be most appreciated.
Thanks!
Posted: November 08, 2010 at 6:06 PM / IP Logged
Shrink sleeve 1/4" over the terminals or bases from Radio shack etc.
Ween
Platinum - Posts: 1,368
Posted: November 08, 2010 at 8:46 PM / IP Logged
hi,
maybe something from here: http://www.allelectronics.com/make-a-store/category/525/Relay-Sockets/1.html
and solder wiring to the socket and add heatshrink per Howie's post.
mark
batook
Member - Posts: 13
Posted: November 08, 2010 at 10:19 PM / IP Logged
Yeah, I considered heat-shrink tubing for the terminal leads too.  I guess that's what I'll have to do.  Thanks for the pointers and links.
ckeeler
Gold - Posts: 1,461
Posted: November 08, 2010 at 10:44 PM / IP Logged
What is the brand, and part # of your relay?
Posted: November 09, 2010 at 12:17 PM / IP Logged
Funnily enough you can buy the kit of parts, base and non-insulated click in terminals quite easily here, Armour Auto, UK page 227, I've tried Metra and Scosche with no luck, though I'm sure DEI or other alarm manufacturers do something similar in their accessory sections.
Ween
Posted: November 09, 2010 at 12:31 PM / IP Logged
i'm guessing his choice of the relay is more of an industrial/power control type rather than automotive type.  looked at the parts express website and searched relays, looking at the 12V DC DPDT offerings.
Posted: November 09, 2010 at 1:56 PM / IP Logged
Actually the whole questions, daft with a normal relay just use crimp type connectors, mind you as CK said he hasn't bothered to tell us what type.
