wiring door lock/unlock 1999 ford f150
s13silvia
Member - Posts: 10
Posted: November 13, 2010 at 11:58 PM / IP Logged
I  found the wires for the door locks, upper d/s firewall.  My remote start wires for door lock/unlock are negative trigger. Do I connect these wires straight up and thats it? Its a 1999 ford f150, with power locks.
Posted: November 14, 2010 at 3:34 AM / IP Logged
The info is here, vehicle wiring charts are your friend, use them and don't expect to be spoon fed.
smokeman1
Platinum - Posts: 1,589
Posted: November 14, 2010 at 7:10 AM / IP Logged
Probably yes.  What model of remote start are you using?
Posted: November 14, 2010 at 7:46 AM / IP Logged
If existing key less entry, neg so your R/S is OK. Use diodes, 1N4004 bands away from R/S.
If not keyless, then 5 wire, use 2 relays as per the instructions on the relay site here or better DEI 451.
Incidentally if you found the wires why are you even asking?
Don't you have a DMM?
s13silvia
Member - Posts: 10
Posted: November 14, 2010 at 10:18 AM / IP Logged
I have read into it, some people say they are using relays some people not. I do not know what circumstance you would need relays. Thats why I ask.
s13silvia
Member - Posts: 10
Posted: November 14, 2010 at 10:20 AM / IP Logged
Prostart CT-3271 http://www.autostart.ca/prostart/prod-en_CT-3200.php
Posted: November 14, 2010 at 10:58 AM / IP Logged
I've already given you the answer and you've quoted it. If you don't understand it's not my problem.
smokeman1
Posted: November 16, 2010 at 8:04 PM / IP Logged
Factory Keyless Entry or no Factory Keyless Entry???
s13silvia
Member - Posts: 10
Posted: November 17, 2010 at 6:34 AM / IP Logged
Im guessing no factory keyless entry bought truck used just came with two keys. Anyway to find out if maybe it had keyless and the fob just got lost?
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
