06 trailblazer tach wire?
dgreen4298
Posted: December 16, 2010 at 2:50 PM / IP Logged
what tach wire do you guys use for an 06 trailblazer?  the wire color and location lists say white wire c1 connector at pcm pin 49 but i dont have a white wire there.  my connector view in repair manual shows that as cruise control signal gray wire.  i do see a white wire at pin 31 labled as engine speed signal. does that sound right to you?  it is a 06 trailblazer with a v6 auto.
kgerry
Platinum - Posts: 3,455
Posted: December 16, 2010 at 3:46 PM / IP Logged
voltage sense, 4 sec crank.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
zerepdivad
Silver - Posts: 605
Posted: December 16, 2010 at 8:11 PM / IP Logged
Tachometer          WHITE          (AC)          IN BLUE PLUG ON PASSENGER SIDE OF ENGINE
A DMM is a beautiful thing.
dgreen4298
Posted: December 16, 2010 at 8:19 PM / IP Logged
thanks for replying.  what blue plug are you talking about on the passanger side of engine? what does it plug into? where is it mounted
Mike M2
Platinum - Posts: 2,652
Posted: December 17, 2010 at 6:32 AM / IP Logged
White wire, back of cluster....
Mike M2
Tech Manager
CS Dealer Services
Thursday, January 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
