dodge ram 2010
muaiad97
Copper - Posts: 207
Posted: December 18, 2010 at 10:00 PM / IP Logged
hi guys
i have this truck 2010 ram i need to install  remote starter  it looks hard to install  to me because the wiring diagram  says  no starter wire and no acc wire and no ign wire  required for remote starting  so how the truck will start without these wire  i had to buy  by pass madual it called EVO ALL  i am not sur if this madual can do the starting anyone have done this truck befor so i can get more information. the remote starter is  AUTO START  2 WAY FM.
thanx
Ween
Platinum - Posts: 1,368
Posted: December 18, 2010 at 10:23 PM / IP Logged
hi,
you may want to see if you can acquire a Flashlogic FLCAN module instead, flashed to your vehicle of course. it makes the install rather basic as the module performs the transponder bypassing, door locks, and ignition switch operations. they also have an interface harness available (FLCHH) that connects inline with the ignition harness to even simplify the install more.
hope this helps
mark
muaiad97
Copper - Posts: 207
Posted: December 19, 2010 at 8:55 PM / IP Logged
hi
thanx for replay but still this madual does the starting or not  because i paid $120 for  this madual but still i didnt  work in this truck i am wating for correct diagram .
thanx
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
