viper 5701 on nissan frontier 08
joelr7309
Copper - Posts: 97
Posted: December 27, 2010 at 2:49 PM / IP Logged
I haven't been back on this website since I google my users name and it showed up... I did a Viper 550 ESP back in 2002 on my Acura Integra remote start manual 5speed and was successful from the help of the folks in here which was my first alarm. Thanks again
Easy but time consuming
I bought a 2008 Nissan Truck which is also a stick and I'm trying to install a Viper 5701 alarm on the truck. Here are my questions
1. Do I need a bypass or immobilzer for this truck which my truck is the lowest class just the key. I'm not sure if this key has a chip or dio what ever you call it
2. anyone have the wiring diagram for my truck, I only found the exterra wire diagram hoping its the same... MANY THANKS
Platinum - Posts: 7,828
Posted: December 27, 2010 at 4:27 PM / IP Logged
Here is a link to Bulldog Security for wiring info : http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Here is a link to AudioVox for their wiring info :  http://techservices.audiovox.com/login.aspx  Sign-up is free.
The 2008 Frontier should have a transponder immobilizer system.  There are many good bypass' available for this vehicle.
joelr7309
Copper - Posts: 97
Posted: December 27, 2010 at 10:52 PM / IP Logged
Thanks brotha, I see some of the wire. I keep this posted when I finish my project
joelr7309
Copper - Posts: 97
Posted: December 28, 2010 at 1:33 PM / IP Logged
Need help putting power door locks..
My truck came bone stock didnt come with power door locks so i bought 2 door accuators and tried this diagram to install
viper 5701 on nissan frontier 08 -- posted image.
my 5 pin relays smoke like crap as soon as i put the 12vlt positive live..
I guess this diagram wasn't correct.
anyone have any other diagram to try
Posted: December 28, 2010 at 3:07 PM / IP Logged
Here is a diagram from AudioVox :  http://documents.audiovox.com/701139.pdf
joelr7309
Copper - Posts: 97
Posted: December 28, 2010 at 3:19 PM / IP Logged
Kool man thansk again. hope this works..
Wondering does it matter what type of 5 pin relay to use. I'm using a 12vlt 30 amp relay I got from the autozone
Posted: December 28, 2010 at 5:20 PM / IP Logged
The basic Bosch 30/40A SPDT automotive relay is fine.
joelr7309
Copper - Posts: 97
Posted: December 31, 2010 at 3:27 AM / IP Logged
Thanks for the relay help. The thing was driving me crazy, So I just bought the DEI 451M lock mod.
I hooked up the follow to my Viper 5701
RED / GREEN/ blue. I had to cut because it had no socket to fit in the alarm so I spliced it to the following connections
red-Constant 12 Volt
Green- to alarm green
Blue- to alarm blue
White
Brown- both ground
Purple- 12 Constant
Blue- Blue Actuators
Green- Green Actuators
I want to put a toggle switch, do I jumper
green and blue from the alarm wires or Actuator wires?
I'm thinking the alarm wires
I was right I it was the alarm side..Nevermind
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
