2009 corolla s
blwnrat
Posted: January 11, 2011 at 10:48 PM / IP Logged
I'm helping a friend install a double din DVD in his '09 Corolla S and I'm looking at the harness... there are 4 different plugs... We have 12v constant on the light blue wire but I cannot find the acc wire... It says its gray but I've metered every single gray wire in the radio harness with the key on and the only wire showing voltage is the light blue constant... any ideas???
Mike M2
Platinum - Posts: 2,652
Posted: January 12, 2011 at 6:04 PM / IP Logged
It's there, right next to the light blue wire. Both are in the largest plug(in size not pins), 10 pins total, the gray accessory wire is pin 3. You 12volt constant you already found is in pin 4. If there's no power at this gray wire you blew a fuse.
Mike M2
Tech Manager
CS Dealer Services
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
