04 durango factory disarm
yayay
Member - Posts: 17
Posted: January 13, 2011 at 4:05 PM / IP Logged
i have the compustar remote start with the blade type bypass everything went fine except the factory disarm is still coming on when the truck is remote started
Platinum - Posts: 7,783
Posted: January 13, 2011 at 4:22 PM / IP Logged
Did you connect Keysense?
Key Sense            PURPLE / TAN  (-)                    IGNITION SWITCH HARNESS
simplyfalling
Copper - Posts: 69
Posted: January 13, 2011 at 4:44 PM / IP Logged
I have had to wire up keysense, like Kreg suggested, but also had to turn on unlock before start and lock after start.  If your using a blade style unit, then with the compustar its probably option 1-01.
tedmond
Gold - Posts: 4,610
Posted: January 13, 2011 at 6:51 PM / IP Logged
the keysense should disarm it without unlocking.
Ted
Compustar Expert
simplyfalling
Copper - Posts: 69
Posted: January 14, 2011 at 8:49 AM / IP Logged
It should, but it doesnt always.  I have personally had to do this on atleast three durangos this month.  The keysense will only keep the truck from rearming the alarm.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
