new prostart remote starter
rob b
Member - Posts: 9
Posted: January 14, 2011 at 3:03 PM / IP Logged
Hello i am new to the site i have picked up a 3in1 prostart alarm and am trying to install it in my 2001 ford f350 S.D./ v10 gas truck..   I tryed to find the wiring for my ford thu the prostart web site and it does not show the one for my truck the only one it shows is for 2002 and the wiring is wrong i have part of it hocked up can someone please email me the right wiring for my truck   ""my truck is all torn apart and damn its cold out'' new prostart remote starter -- posted image.
2001 ford f350 SD 9 inch lift kit with 54inch tires
Platinum - Posts: 7,828
Posted: January 14, 2011 at 4:58 PM / IP Logged
Audiovox has a wire "Guide" for your truck :  http://techservices.audiovox.com/Login.aspx   Sign-up is free.
Here is info from Bulldog Security
FORD
 MODEL                                 YEAR(S)
 F SERIES SUPER DUTY   1999 -2001
  PART                                                        COLOR        LOCATION
 12 VOLT CONSTANT          YELLOW (+) and LIGHT GREEN/ PURPLE (+)                                       IGNITION SWITCH HARNESS
 STARTER                              RED / LIGHT BLUE (+)        IGNITION SWITCH HARNESS
 STARTER 2  N/A
 IGNITION 1                            RED / BLACK (+) (use the Larger of the 2 wires)                                     IGNITION SWITCH HARNESS
 IGNITION 2                            BLACK/ LIGHT GREEN (+)        IGNITION SWITCH HARNESS
 IGNITION 3  N/A
 ACCESSORY 1                    GRAY / YELLOW (+) (use the Larger of the 2 wires)                IGNITION SWITCH HARNESS
 ACCESSORY 2                     N/A
 KEYSENSE                            N/A
 PARKING LIGHTS ( - )         N/A
 PARKING LIGHTS ( + )        BROWN (+)        @ HEADLIGHT SWITCH
 POWER LOCK                      PINK / YELLOW (TYPE C)                                                            See NOTE *1   See NOTE *1
 POWER UNLOCK                PINK/LIGHT GREEN (TYPE C)                                                 See NOTE *1   See NOTE *1
 DOOR TRIGGER                  BLACK/ BLUE (+)        Located in a GREY Molex plug, to RIGHT of the Steering column
 DOMELIGHT SUPERVISION  USE DOOR TRIGGER,              Requires Part #775 Relay
 TRUNK RELEASE                N/A
 SLIDING POWER DOOR     N/A
 HORN                                      DARK BLUE (-)        @ STEERING COLUMN HARNESS
 TACH                                       WHITE/ PINK, See NOTE *2                                                     @ the INSTRUMENT CLUSTER or PCM
 WAIT TO START LIGHT        See NOTE *2
 BRAKE                                     LIGHT GREEN (+)        @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM   N/A
 ANTI-THEFT                             N/A
 EXTRA INFORMATION
 NOTE *1 Vehicles with FACTORY KEYLESS ENTRY are a TYPE "B" Door locking system, wire are located in a GREY Molex plug on the RIGHT side of the Steering column, vehicles without FACTORY KEYLESS are a TYPE "C" Door locking system, when doing TYPE C Locks, use the DRIVERS side SWITCH when TESTING. Wires are located in the DRIVERS DOOR HARNESS. NOTE *2 On DIESELS the TACH wire is a WHITE/ PINK located at the PCM (Powertrain Control Module) or at the Main Harness that runs on the inside of the firewall to the left of the brake pedal. For WAIT TO START LIGHT, do not use the wire in the vehicle, use the 5,10,15 or 20 Second PROGRAMMABLE Wait To Start Timmer on the Remote Starter.
rob b
Member - Posts: 9
Posted: January 14, 2011 at 9:08 PM / IP Logged
Thanks I will have it done in the morning thanks for your time .
tedmond
Gold - Posts: 4,610
Posted: January 14, 2011 at 11:48 PM / IP Logged
easy truck, but pos alarm. The starter works great, good range and decent 2way capabilities.
if the shock sensor goes off, it doesnt page the remote. installed a few, and they worked great, but not worth the money.
Ted
Compustar Expert
rob b
Member - Posts: 9
Posted: January 16, 2011 at 8:32 AM / IP Logged
 Hello again so yes I tryed to install the remote starter and I had no luck it seems like
 the equipment was bad this is how I installed it.
 Remote starter wires.       //           Truck wires.
 2 red 12 volt             to         2 yellow 12 volt wires Hot all the time. NOTE 2 YELLOW WIRES.
 yellow ignition           to         RED / black big wire
 orange accessories        to         gray / YELLOW big wire
 Purple starter            to         RED / light blue wire
 green 5th relay           to         ------------------- BLACK TAPE..
 black                     to           ground-
 purple                    to           TACH ac.
 gray                      to           hood switch+
 orange                    to           brake switch+
 yellow                    to           parking lights brown wire+
 I did install the SIREN and no start at all did i do something wrong
 i did not hook the doors up yet i was trying to get it to start frist
 So I took it back and got a new one its here in the box i am not sure
 if i want to do this its cold outside..lol. ware did i go wrong with it ?
 i closed the hood lights flashed 4 times NO siren sound at all HELP Would
 be nice guys PLEASE..
tedmond
Gold - Posts: 4,610
Posted: January 16, 2011 at 9:15 AM / IP Logged
you need to program remotes and tach then you can start it up. what bypass module you using?
Ted
Compustar Expert
rob b
Member - Posts: 9
Posted: January 16, 2011 at 9:28 AM / IP Logged
I am not using a module my key is not chiped so i don't need one do i?
Posted: January 16, 2011 at 9:29 AM / IP Logged
Also ign 2 needs connecting, BLACK/ light green, what EXACTLY happens when yo try to activate it? Have you programmed tach and remotes?
Also use a spell-check, it goes to your workmanship! You should contact Tedmund if you are local, pay him to install this properly.
Platinum - Posts: 12,488
Posted: January 16, 2011 at 9:33 AM / IP Logged
ProStarts you need to program remote and also tach wire. No bypass required for the Super Duty's ( except in 2008+ ). Also, the IGN wire may also be a BLUE/GREEN instead of the RED / BLACK. Check to see that you have the proper IGN wire.
Posted: January 16, 2011 at 10:11 AM / IP Logged
Have you checked the outputs of your original unit?
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
