memphis pr200.2 problem
monitor2
Member - Posts: 14
Posted: January 30, 2011 at 5:02 PM / IP Logged
Hi im a new member and i need help my neighbor gave me this amp to start off my system he said it might or might not work because it didnt a while back but i tried it and its still doing the same thang when i turn it on it Goes into protect. It goes off protect when gain is turned all the way down. any help is appreciated.
Platinum - Posts: 13,725
Posted: January 30, 2011 at 5:07 PM / IP Logged
The amp has one or more shorted output transistors.   Connect only the power, ground and the remote turn on wires.  If it still has this problem, it will be a simple repair.
monitor2
Member - Posts: 14
Posted: January 30, 2011 at 5:10 PM / IP Logged
thnak you i will check this out in a little bit
monitor2
Member - Posts: 14
Posted: January 30, 2011 at 7:52 PM / IP Logged
I checked inside my amp there is a white rectangle thing two of the three connections were not connected by solder what is that and could that be my problem
Posted: January 30, 2011 at 8:13 PM / IP Logged
Yes that could be your problem.  That problem only shows up if you run signal into the amp.  That is why I wanted you to connect only power ground and remote to see if it still did the same thing.  Reconnect the connections and see what happens.
The device is the emitter resistor.  There are 2 resistors in that one case.
memphis pr200.2 problem -- posted image.
This is not the value of your resistor. This is only to confirm that we are talking about the same part.
monitor2
Member - Posts: 14
Posted: January 30, 2011 at 8:14 PM / IP Logged
ok i will try that i was about to post picture thank you
monitor2
Member - Posts: 14
Posted: January 30, 2011 at 8:38 PM / IP Logged
Do you know where i can buy one of these
Posted: January 31, 2011 at 9:15 PM / IP Logged
What is the value of the one in your amp?  .1, .22, .33Ohm?
monitor2
Member - Posts: 14
Posted: January 31, 2011 at 10:21 PM / IP Logged
.15 Ohm
monitor2
Member - Posts: 14
Posted: February 05, 2011 at 5:23 PM / IP Logged
This came out of a Memphis Pr 200.2
I was told it was an emitter resistor but not sure. Also would like to know the place i can get another if possible.
Sorry the picture is bad quality the writing on it is:
MPR 55F
0.15ŮKX2
DAE LIM
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
