2010 ford edge auto lights
gregbbb
Copper - Posts: 82
Posted: February 17, 2011 at 10:11 PM / IP Logged
 Does anyone know how to turn the auto lights off at night / remote started on the 2010 Ford Edge?
I have installed a 5901 viper is there a wire I can cut and relay to the ground while runing wire?
Ween
Platinum - Posts: 1,368
Posted: February 17, 2011 at 10:26 PM / IP Logged
are you trying to keep the headlights off while running on remote start?
as at night or when dark, the vehicle turns the headlamps on? use negative parking lights at the headlight switch. if customer leaves headlight switch at auto, doing parking lights negative removes ground feed to switch (disabling auto lamps) and forces the parking light input of the SJB on. you can adjust the turn off delay of the headlamps when ignition is turned off i believe.
cmk0808ny
Copper - Posts: 203
Posted: February 18, 2011 at 3:38 AM / IP Logged
you can just leave it. most time out after 30 sec. can use the pos lites in kick panel instead of using a relay. it overrides the auto mode during the day and the park lites come on.
gregbbb
Copper - Posts: 82
Posted: February 18, 2011 at 11:28 AM / IP Logged
Yeah I guess I will have to just live with it the gray (-) at the light swith is not (-) like the the info says it (+) when lights turn on.
cmk0808ny
Copper - Posts: 203
Posted: February 18, 2011 at 12:10 PM / IP Logged
You need to cut the wire and put a relay in it or else you will burn outbthe lightnswitch and the vehicles lights will not go off until it is fix or replaced. Be careful.
Mike M2
Platinum - Posts: 2,652
Posted: February 20, 2011 at 9:19 AM / IP Logged
I agree with positive in the DKP, much easier on this car....
Mike M2
Tech Manager
CS Dealer Services
Ween
Posted: February 20, 2011 at 1:23 PM / IP Logged
i believe the issue is the headlights coming on at night when remote started, because the headlight switch is left in the 'auto' position. not sure how wiring the parking lights positive is going to stop the autolamps system from being triggered. enlighten me?
mark
cmk0808ny
Copper - Posts: 203
Posted: February 20, 2011 at 4:34 PM / IP Logged
easy way is to leave in the off position. the postive would make the park lites come on during the day while in auto mode.
i dont think anybody stops the autolamps from coming on at night. it actually is better- it lites the way to the car at night.
