viper 5902, 98 honda civic ex
buddholly
Copper - Posts: 244
Posted: March 04, 2011 at 3:19 PM / IP Logged
and you do not need a bypass. you just need to move your starter wires to that BLACK/ red I mentioned.
bryanmc1988
Member - Posts: 48
Posted: March 04, 2011 at 3:32 PM / IP Logged
really helpful but confused about this part
"To do clutch bypass run your starter wires to the BLACK/ red starter wire above the driver kick panel instead of the starter wire at the ignition harness."
can u be more specific? what wire to the BLACK/ red starter wire? and what do i need to connect?
on the viper harness i still have the violet and green and what about the BLACK/ white starter wire from the ignition? do i connect the BLACK/ white starter wire from the ignition back together? can u label what goes where? i'll go check my car now to see if i can find a BLACK/ red starter wire and is it a fat BLACK/ red or just a small kind?
bryanmc1988
Member - Posts: 48
Posted: March 04, 2011 at 3:43 PM / IP Logged
also is this the tech wire? its under the hood far driver side next to the fender in a rubber black casing... i'm pointing at it... is that a tech wire also? cause i have it hook up to that but not sure
viper 5902, 98 honda civic ex - Page 3 -- posted image.
buddholly
Copper - Posts: 244
Posted: March 04, 2011 at 3:50 PM / IP Logged
Tach can be found here.
Starter Wire is here. Purple to car side. Green to key side. And yes reconnect the BLACK/ White starter wire like you never cut it.
bryanmc1988
Member - Posts: 48
Posted: March 04, 2011 at 4:19 PM / IP Logged
ok still a little confused let me try to figuer what your saying ... ok
1) so the BLACK/ white starter wire from the ignition is wired back together as if it was never cut...
2) the BLACK/ red starter wire above the driver kick panel cut that in half and the violet and green wires from th viper connects to the BLACK/ red wire from the car correct? confusing but let me clean it up in pictures lol
              BLACK/ red wire from car
8-pin   | |
connector | |======================= Key side? i assume
side    | |
then you cut it in half
8-pin   | |           |
connector | |======== cut    ======== Key side? i assume
side    | |           |
then u wire it like this?
8-pin   | |           |
side    | |     |     |        |
   |        Green wire form
   |        viper H3 harness
           violet wire from
           viper H3 harness
correct me if i'm wrong....
Posted: March 04, 2011 at 4:43 PM / IP Logged
Again on your last post you've written key side ASSUMED.
Don't EVER assume, test.
bryanmc1988
Member - Posts: 48
Posted: March 04, 2011 at 5:17 PM / IP Logged
buddholly should know what i am talking about... its the BLACK/ red wire that he was talking about... i think e ment to tell me to cut it but not sure trying to confirm if what i just post was the right way
buddholly
Copper - Posts: 244
Posted: March 04, 2011 at 5:30 PM / IP Logged
For now I would just connect the purple wire on H1 to the BLACK/ red and don't worry about the green on the H1. It will start like that.
As far as your tach question, I really don't know if thats the right wire or not without having the vehicle in front of me. Start the car with the key, press and hold the button on the antenna (the thing that has the blue light on it, if the blue LED comes on after a few seconds it should have learned the tach signal (You have to do this or it won't work, so make sure you are doing this) Since it doesnt sound like you have a multimeter I would just move it to the wire that's pictured above.
bryanmc1988
Member - Posts: 48
Posted: March 04, 2011 at 6:16 PM / IP Logged
i do have a multi meter but how can u tell if its a tech wire or not?
also so for the violet wire i just hook it up to the BLACK/ red starter wire right? but dont cut the BLACK/ red starter wire in half right? need a confirmation on do i cut the BLACK/ red or not
bryanmc1988
Member - Posts: 48
Posted: March 04, 2011 at 7:43 PM / IP Logged
ok good news and bad news.....
GOOD NEWS:
i got remote start to work.....
Bad news:
every time i turn off remote start, i need to repeat the steps to get mts mode for remote start to work next time
so how do we set it so that the remote start works every time when pushing the remote start button
Page of 7
