alarm/remote start, 2002 pontiac sunfire
twistable_deer
Member - Posts: 8
Posted: April 13, 2011 at 4:57 PM / IP Logged
hi, i bought a prostart remote starter for my 2002 Pontiac sunfire and i was wondering why it does not what to unlock or lock the car, the lights flash and everything but nothing happens. do i need a relay to unlock?
Platinum - Posts: 7,827
Posted: April 13, 2011 at 5:41 PM / IP Logged
Here is a link to Bulldog Security for wiring info : http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Depending on whether or not the car came with Factory Keyless Entry, you will have either Type A or Type C
door locks.  Bulldog Note :   NOTE *1 if vehicle is WITHOUT Factory Keyless entry it is a TYPE C Door
Locking system and MUST be tested from the PASSENGER SWITCH, if vehicle has Factory keyless Entry it is
a TYPE A Door Locking System.
Here is some info on wiring the locks:
Type A Three Wire Positive :  http://www.circuitbuddy.net/products.htm
Type C REV  :  https://www.the12volt.com/doorlocks/page3.asp#5w
If your remote starter unit only outputs a (-) lock / unlock pulse, you will need relays and a inline fuse.
Other options include a bypass module that does both the Passlock2 immobilizer and the door locks or a
DEI 451m relay module for the door locks.
syl20rochon
Copper - Posts: 298
Posted: April 13, 2011 at 7:35 PM / IP Logged
If your car is non keyless, it is easily done with 2 relays as a reversal 5 wire circuit. If it's keyless, again 2 relays will be needed but wired differently. We just need to know which one you have.
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
twistable_deer
Member - Posts: 8
Posted: April 13, 2011 at 7:36 PM / IP Logged
so where do i get those relays?
syl20rochon
Copper - Posts: 298
Posted: April 13, 2011 at 7:44 PM / IP Logged
Any electronic store or autoglass shop. In canada, their worth about $5 to $8 each. Get them with 12" harnesses. Do you have keyless or not?
Sylvain Rochon
I'm here to help.
twistable_deer
Member - Posts: 8
Posted: April 13, 2011 at 7:47 PM / IP Logged
no, it only unlocks, locks and opens my trunk. it also has a panic button.
syl20rochon
Copper - Posts: 298
Posted: April 13, 2011 at 7:50 PM / IP Logged
So you do have a keyless GM remote! Right?
Sylvain Rochon
I'm here to help.
twistable_deer
Member - Posts: 8
Posted: April 13, 2011 at 7:52 PM / IP Logged
yes i guess it unlocks/locks my car
syl20rochon
Copper - Posts: 298
Posted: April 13, 2011 at 8:03 PM / IP Logged
So this is the way you'll wire your relays. I'm giving you the lock relay, just repeat for unlock.
85= lock wire from remote brown (-)
86 & 87= +12V (Fused 10amps)
30= lock wire from car (Driver kick panel)(+) Light Blue
Repeat for unlock
unlock from remote starter= Green (-)
unlock from car= White (+)
The relays you'll get are rated at 30 amps and the pin numbers are written on the relay itself. Make sure that you fuse you relays, one 10 amps fuse will do for both relays as you will wire all 86 & 87 pins together to the fuse.
Sylvain Rochon
I'm here to help.
twistable_deer
Member - Posts: 8
Posted: April 13, 2011 at 8:08 PM / IP Logged
so the 85, 86, 87, and 30 will be the relay i would have to buy? sorry i am new to this
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
