board diagrams?
b00nd0ck xs41nt
Member - Posts: 16
Posted: May 11, 2011 at 10:25 AM / IP Logged
So one thing shorting, could have damaged something else? I have pictures, I'll link them from facebook if that's allowed.
board diagrams? - Page 2 -- posted image.
[im]http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/224266_2033622358650_1186915035_2487150_7830444_n.jpg[/img]
DJ Jack Ripper, Car audio noob (sort of)
b00nd0ck xs41nt
Member - Posts: 16
Posted: May 11, 2011 at 10:26 AM / IP Logged
since it didn't work in the last post.
Platinum - Posts: 13,726
Posted: May 11, 2011 at 4:54 PM / IP Logged
After you find the shorted output transistors, take a pic of that channel so I can do the same for those parts as I have done for the supply.  You only took a picture of the one side of the board.  There are 2 transistors on the other side of the amp that also need to be replaced.  Every component with the white dot needs to be checked or replaced.  What is the resistance of the 2 resistors on this side of the amp?  What about the 2 on the other side?  Do you know how to check a bi-polar transistor with a digital meter?
b00nd0ck xs41nt
Member - Posts: 16
Posted: May 11, 2011 at 10:27 PM / IP Logged
It's been a while since I've had to do any electrical work, but IIRC, I need to set the MM to Ohms, check resistance on each circuit, and if it's above 1. something, it's bad, or if it has no continuity at all? Sorry, it really has been a while since I've had to bust out my multimeter.
