04 sienna power sliding door
sgarcia1212
Member - Posts: 40
Posted: May 17, 2011 at 9:11 AM / IP Logged
Hi Guys,
I'm in the process of installing a Viper 350 plus to my 04 Toyota sienna.
Do I need a relay to connect the power sliding door to the auxiliary channel? or can I connect it directly to the alarm?
I don't know if the pulse for the power sliding door is negative.
can somebody please provide me a wiring diagram for my 2004 Toyota sienna?
please help.....
thanks...04 sienna power sliding door -- posted image.
sgarcia1212
awdeclipse
Copper - Posts: 285
Posted: May 17, 2011 at 9:18 AM / IP Logged
From Bulldogsecurity.com
SLIDING POWER DOOR      YELLOW /GREEN (Left) (-) and PURPLE (Right) (-) See NOTE #5, (Requires Part #775 Relay)      @ BOTTOM LEFT of FUSEBOX, 22-PIN Plug
Not sure if your particular alarm needs a relay or not.
Platinum - Posts: 7,827
Posted: May 17, 2011 at 11:20 AM / IP Logged
As awdeclipse noted, the power sliding door requires a (-) pulse to open ( or close ).  No relay is required, just connect the (-) 200mA AUX output to the correct / vefified wire listed above.
syl20rochon
Copper - Posts: 298
Posted: May 17, 2011 at 6:51 PM / IP Logged
There you go....
FUNCTION     DATACOLOR     LOCATION     POLARITY     PICTURE
+12 Volts     WHITE/ Red     Ignition Harness     +
Ignition     Black     Ignition Harness     +
Ignition 2     Small BLACK / YELLOW     Ignition Harness     +
Accessory     Small Pink     Ignition Harness     +
Accessory 2     N/A     N/A     N/A
Starter     BLACK / YELLOW     Ignition Harness     +
Starter 2     N/A     N/A     N/A
Tachometer     Black     At Engine control module behind glove box     AC
Injector     N/A     N/A     N/A
Parking Lights     GREEN/ Black     Ignition Harness     -
Brakeswitch     GREEN / WHITE     at fuse box     +
Clutch Bypass     N/A     N/A     N/A
Parking Brake     N/A     N/A     N/A
Hoodpin     N/A     N/A     N/A
Glow Plug     N/A     N/A     N/A
Lock     Light Green     Driver's kick panel     -
Unlock     Blue     Driver's kick panel     Double Pulse (-)
Trunk Release     Yellow/Red     **See Notes     -
Arm     Arms With Lock     N/A     N/A
Disarm     Disarms with Unlock     N/A
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
sgarcia1212
Member - Posts: 40
Posted: May 22, 2011 at 3:42 PM / IP Logged
thank you guys.
sgarcia1212
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
