time alignment wiring
dukesrebelyell
Member - Posts: 33
Posted: June 03, 2011 at 6:41 PM / IP Logged
i was wondering if anyone has a wiring diagram for time align speakers. i saw a schematic for it once but i cant remember where. the head unit im going to buy has the function built into it, its the jvc kdr9 series or something like that, wish i could afford the stage 4 from pioneer though. any help will be great. thanks
35 Hertz custom car audio and automotive fabrication
Platinum - Posts: 13,725
Posted: June 03, 2011 at 9:41 PM / IP Logged
I do not know of any way you could wire a speaker and delay the signal.  Well no practical way.
the12volt
Administrator - Posts: 3,959
Posted: June 03, 2011 at 10:13 PM / IP Logged
You may have seen some type of lattice filter, but what exactly are you trying to accomplish? Are you trying to align two drivers in an enclosure? Or are you wanting an adjustable listening position?
time alignment wiring -- posted image. the12volt • Support the12volt.com
dukesrebelyell
Member - Posts: 33
Posted: June 03, 2011 at 10:22 PM / IP Logged
Its for positioning the focus on the drivers seat of a vehicle. The article that read if I remember correctly was talking about how phase or cycle shifts by so many degrees after passing through a load. It also said that you have to do this with a two channel amp and it won't work with a 4ch. Its a way of wiring the mid/high and it may not be an actually delay but more of a shift in the soundwave Which causes the signal from each speaker to hit the same point at the same time.
the12volt
Posted: June 03, 2011 at 11:34 PM / IP Logged
Since you intend to purchase a head unit with a digital time delay feature, there is no need to wire anything differently and it will have line outputs for front/rear/sub, so you won't be limited to just a two channel amplifier. I can't imagine any passive solution that would work as well as a DSP, but I'd still like to read that article.  BTW, is this the head unit? http://mobile.jvc.com/product.jsp?modelId=MODL028809&pathId=142&page=2
haemphyst
Platinum - Posts: 5,059
Posted: June 04, 2011 at 7:48 AM / IP Logged
This is a new one on me...
The MOST you can effectively shift any analog wave is 360 degrees, and then you are back in phase. The most you can DELAY any analog wave is infinite. See the disparity here? Phase Shift vs. Time Delay is like asking the San Diego Chargers to play the LA Dogers in a game of basketball. They're all very different things and are achieved COMPLETELY differently.
Speaking from experience, the TD is a really nice thing to have, but I know of no way to do it passively, other than tens of thousands of feet of wire. Yes. PER SPEAKER! Through any inductor or capacitor there will be a phase shift, this is true, but there won't ever be any time delay worth mentioning. On the order of picoseconds (or even smaller timeframes). TD is really only practical in a digital processor. All that being said, I can't also see ANY reason that if a two-channel amplifier WOULD work, that a four-channel amplifier would NOT work. A four-channel amp is just two two-channel amps in one chassis... Nothing else.
Using any circuit with inductors and capacitors (like a crossover) can certainly (and absolutely DOES) shift phase, but it also bandwidth limits the frequency response. It's most certainly not the same thing.
DYohn
Platinum - Posts: 10,741
Posted: June 05, 2011 at 9:20 AM / IP Logged
Passive time alignment can be accomplished through driver positioning, but that is not really practical in a vehicle.  As theVolt said, DSP is likely your best choice.
