airbag removal
t&t tech
Platinum - Posts: 2,622
Posted: November 04, 2011 at 5:20 PM / IP Logged
Wanna remove the airbags from my car guys, do i risk triggering the airbag light if i do? I'm just gonna remove all the plugs at the points of termination at the airbag holder, car is a 1998 Nissan Primera.
KPierson
Platinum - Posts: 3,527
Posted: November 05, 2011 at 6:21 AM / IP Logged
Typically the air bags are supervised meaning that if you simply remove them the light will come on. On many cars it is as simple as putting the CORRECT resistor across the wire harness.
Kevin Pierson
Posted: November 06, 2011 at 1:20 AM / IP Logged
Is it really do-able Kevin, Darren don't you have annual tests?
By the way Kevin, hopefully early congratulations.
KPierson
Posted: November 06, 2011 at 5:20 AM / IP Logged
I've seen people replace seats with airbags in them for racing seats with no airbags. I don't think I've ever seen anyone just remove a dash airbag or a curtain airbag.
When swapping out seats that is when I have seen people use resistors to keep the airbag light from coming on.
Thank you Howie!
Kevin Pierson
Posted: November 06, 2011 at 5:51 AM / IP Logged
Disconnect battery wait 20 mins, and or flash the terminals together, measure the resistance at those plugs, replace with matched resistor, re-connect battery and away you go.
After this my next post will probably be as a rookie.
