tech tip document 1077
mdd2002
Posted: December 08, 2011 at 12:18 AM / IP Logged
Does anyone have this document that you can send my way?
Also what is the idea behind isolating the ignition switch?
Finally has anyone done a step by step description of Python 991 with DB-ALL on Nissan frontier?
Thanks guys!
Posted: December 08, 2011 at 2:32 AM / IP Logged
Done*; the explanation is in the file but I came across and independently solved this problem on European Peugeots a couple of years ago.
Ignitions 1 and 2 are commoned. If you R/S the vehicle with the alarm on it feeds back down to ignition 1 and triggers the alarm, also you can get a feed back which might affect the engine management.
* Look in the Downloads/Manuals section.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
