clifford intellistart 4 issue
mitchfa
Posted: December 17, 2011 at 2:56 PM / IP Logged
Hello all
My intellistart works great for the most part. My only question is when I have the car started and want to leave it running I press the button and the starter engauges and grinds. I have re-set the tach but that does not seem to help. Is this part of the voltage setting? If so what should the voltage be set at?
99 GMC Suburban
Posted: December 17, 2011 at 5:40 PM / IP Logged
Intellistart only works with tach, there was a second "engineering" method but tach is used on 99% of installs. If the original installer didn't use tach, they were doing something wrong.
More likely no anti-grind installed.
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
