2006 silverado cc remote start
atx06silverado
Member - Posts: 7
Posted: January 08, 2012 at 5:48 PM / IP Logged
Ok so I am watning to install the Viper 5101 Remote Start/Keyless Entry on my truck.  I know that there are several threads out there but not really what I am looking for.  I am wanting info from everyone that has done this install before or that can give me guidence.  Anything that I need to look out for.  Problems that you all had and the soulutions that you used to fix.  Any additional relays that I would need for the doors...or anything else.  Basically any info that would help me in this install.  Thanks ahead of time.
Platinum - Posts: 13,725
Posted: January 08, 2012 at 6:07 PM / IP Logged
You will not need any extra relays for the door locks, but you will need a data module.  The data module will also make the remote start portion much easier. Some of our hands on guys will be able to give you more info on the available modules.
offroadzj
Gold - Posts: 2,043
Posted: January 08, 2012 at 6:46 PM / IP Logged
I recommend using an idatalink bypass ADS-DLSL GM1. It should come pre-flashed so you shouldn't have to flash the firmware. it will control the data bypass, lock, unlock, priority unlock, Arm/Disarm factory alarm, door status output, panic mode, rear defrost control, heated seats control, and tach output.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Platinum - Posts: 7,827
Posted: January 08, 2012 at 7:07 PM / IP Logged
Pretty easy install.  Passlock2 immobilizer system.  Must use module for door locks.  Standard GM
truck ignition wires.
+12V constant       Red x 2          @ ignition harness
Ignition1                 Pink                @ ignition harness
Ignition2                 White             @ ignition harness    *** must power or transmission problems!
Starter                    Yellow            @ ignition harness
Accessory1           Orange           @ ignition harness
Accessory2           Brown             @ ignition harness    ***Optional
Parking Lights    Gray/Black(-)                 @ BCM, Brown Plug, Pin B2
Brake                    White(+)                         @ switch above pedal
Tach                     White (AC)                     @ Instrument Cluster, Pin A5
        @ PCM, Green Plug, Pin 10
                  Not Pink, Black or Brown        @ Any F.I. or Coil
I use iDatalink bypass modules.  There are modules available that can do both the Passlock2
bypass and the door locks / Factory Alarm ( if equipped ).  W2W between the Viper and iDatalink,
only one wire from iDatalink to truck and all the above connections listed above from the Viper
to the truck ( except Tach, which the iDatalink supplies ).  Pre-loaded iDatalink modules for your
truck are ADS-ALSL GM and ADS-DLSL GM1.
atx06silverado
Member - Posts: 7
Posted: January 09, 2012 at 12:57 PM / IP Logged
So this will connect to the remote start and then this will connect to all the other wires in the truck?
atx06silverado
Member - Posts: 7
Posted: January 09, 2012 at 1:01 PM / IP Logged
So your saying just the above wire connections between the truck and the ones from the RS to the idata and taa daaa.
atx06silverado
Member - Posts: 7
Posted: January 09, 2012 at 1:16 PM / IP Logged
On my 99 Prelude I use to have I had a Avital R.S. and I had to have a key in a little box for it to work.  Do I need this.
atx06silverado
Member - Posts: 7
Posted: January 09, 2012 at 1:22 PM / IP Logged
...and whats the difference between ADS-DLSL GM1 and ADS-DLSL GM besides like $30.
offroadzj
Gold - Posts: 2,043
Posted: January 09, 2012 at 3:37 PM / IP Logged
No. GM's use a different style bypass. The datalink bypass will take care of it.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
offroadzj
Gold - Posts: 2,043
Posted: January 09, 2012 at 3:57 PM / IP Logged
I believe the GM1 is just an updated version... but I could be wrong.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
