remote start, 2007 nissan armada
offroadzj
Gold - Posts: 2,043
Posted: February 14, 2012 at 11:37 AM / IP Logged
Check your tach connection. Where do you have it connected? Also, verify that you are getting a solid ground signal on the BLACK/ white neutral safety wire at the actual unit (verifying that the switch is good). Finally, where do you have the unit grounded?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
jiriki
Member - Posts: 16
Posted: February 15, 2012 at 11:52 AM / IP Logged
I do not have the tach wire hooked up. I am attempting to use virtual tach.
I will double check the BLACK/ white neutral saftey wire. If it is not hooked up, I believe all I have to do is ground the wire.
There is a ground bolt near the steering column where a bunch of other wires are grounded to it. I am unscrewing this bolt and adding the remote start ground wires to it.
offroadzj
Gold - Posts: 2,043
Posted: February 15, 2012 at 8:46 PM / IP Logged
Connect an actual tach. Virtual tach is unreliable and can cause starting issues. This probably isn't causing your issue, but it can help prevent future issues.
Tachometer      NOT WHITE/ blue, black, or wht      ac      any ignition coil or fuel injector
Connect the tach, ground the BLACK/ white neutral safety switch, and make sure to use a proper sized ring terminal on the ground wire (don't just wrap the wire around the bolt).
Also, do you have the unit set for virtual tach in the programming menu or is it set to tach? Another thing you can test is to go through the MT sequence as if it were a manual transmission, and see if you can get it to start. If it starts after going through the sequence, then it did not program to AT mode. If it still does not start then you know that is not the issue.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Page of 3
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
