2012 camry bypass
pts760
Copper - Posts: 403
Posted: February 02, 2012 at 9:31 AM / IP Logged
Does anyone know where I can get a bypass for a 2012 PTS Toyota Camry. I've tried ADS and Fortin but can't seem to find anything.
I drink current, eat ohms, and bleed voltage
offroadzj
Gold - Posts: 2,043
Posted: February 02, 2012 at 11:08 AM / IP Logged
If its the same as the 2011, then the Evo-All should do it. I would check with Fortin first to be sure (unless someone on here knows)
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
tedmond
Gold - Posts: 4,610
Posted: February 02, 2012 at 11:17 AM / IP Logged
no bypass solutions yet. only option is key in the box. they have new encryption which could possibly be 120bit.
important notes: pulse child lock with disarm or if the user locks with the factory remote, the aftermarket remote will not unlock doors.
child safety Violet (-) rests at ground when unlocked
Lock - Red (-)
Unlock - Green (-)
pulsing child safety will not unlock doors.
diode isolate disarm to keysense. DO NOT use GWR or status. the security light will stay on in the cluster when key is inserted. Applies to all 2012+ toyota vehicles.
info was gathered from iDataLink dealer bulletins and summed up here.hope it helps.
Ted
Compustar Expert
Mike M2
Platinum - Posts: 2,652
Posted: February 02, 2012 at 6:44 PM / IP Logged
The guys at Idata say they get at least 20 calls a day on this car. They are working on it....
Tedmond, "PTS"...
Mike M2
Tech Manager
CS Dealer Services
tedmond
Gold - Posts: 4,610
Posted: February 02, 2012 at 10:01 PM / IP Logged
forget the RFID in the box
didnt notice it was PTS.
Ted
Compustar Expert
pts760
Copper - Posts: 403
Posted: February 02, 2012 at 10:20 PM / IP Logged
Did a regular cut key 2012 Camry the other day. I used the arm and disarm wires in the vehicle to lock/unlock the doors along with disarm the factory alarm. Piece of cake. We do these for the deal all the time.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 03, 2012 at 6:54 PM / IP Logged
None of the bypass companies have anything for the PTS 2012 Camry yet.
Your options are the following:
1. Wait.
2. Aftermarket remote starter with DEI 1101T, or possibly solder wires onto smart key and use a relay instead of 1101T.
3. Toyota factory remote starter. Installation is easy (the car comes mostly pre-wired) but the part is expensive, range is short, runtime is short, and you NEED the Toyota dealer's scan tool to program the remote starter to the car.
