2000 gmc jimmy, viper 5902
trafficbuck
Member - Posts: 21
Posted: February 02, 2012 at 10:56 AM / IP Logged
I have connected the Blade AL and this is all that I get tach, dome light, door triggers, door lock & horn, I have not connected any of these w2w.
But I do not get unlock???
All the wiring diagrams that I have seen only show (+) for the door unlock and lock
The instruction for the FT 6000 AS the door locks, unlocks & trunck release to connect with a negative (-) 250mA ???
offroadzj
Gold - Posts: 2,043
Posted: February 02, 2012 at 10:58 AM / IP Logged
You must connect the 2nd ignition on that car. Not sure about that one in particular but you can cause transmission damage on many GM's by not connecting it. It is listed in the wiring diagrams for a reason...
I am pretty sure you need 2nd accessory hooked up as well for the heater blower. Make sure that if the unit does not have a flex output (which that compustar does not), you MUST use relays on the 2nd ignition and 2nd accessory wires. Connect as follows:
Pin 85 - (-)200ma 2nd ignition output
Pin 86 - 12v constant fused
Pin 87 - 12v constant fused (20amp)
Pin 30 - 2nd ignition wire in vehicle
Pin 85 - (-)200ma 2nd accessory output
Pin 30 - 2nd accessory wire in vehicle
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
offroadzj
Gold - Posts: 2,043
Posted: February 02, 2012 at 11:06 AM / IP Logged
Is this another GMC jimmy than in your compustar thread? If not, then there is no need to start another thread. If it is another, just like that 2000 GMC Jimmy, this one will also need a bypass. With idatalink bypasses, the ADS-ALSL GM
will do data immobilizer and tach (similar to the blade-al) and the ADS-TBSL KO or ADS-TBSL PL will jsut do data immobilizer (similar to the blade-tb).
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
trafficbuck
Member - Posts: 21
Posted: February 02, 2012 at 11:30 AM / IP Logged
Thank you very much!!!
tedmond
Gold - Posts: 4,610
Posted: February 02, 2012 at 11:31 AM / IP Logged
as metz suggested.
The AL on that car does passlock and tach. That is it.
The TB does passlock only
NO other features are supported as you suggested (locks, domelight, etc)
you will have to make analog connections to the vehicle. the locks are negative from the unit. if the vehicle uses positive locks use 2 relays
85 - lock or unlock from compustar
86 - constant 12v
87 - constant 12v
30 - lock or unlock on vehicle
Ted
Compustar Expert
trafficbuck
Member - Posts: 21
Posted: February 02, 2012 at 11:33 AM / IP Logged
Thank you,
This is different GMC then I posted for the compustar.
tedmond
Gold - Posts: 4,610
Posted: February 02, 2012 at 11:44 AM / IP Logged
if you use the viper the fortin evo-all will work good for your application. does locks, trunk, tach, and bypass.
w2w only.
Ted
Compustar Expert
trafficbuck
Member - Posts: 21
Posted: February 02, 2012 at 1:19 PM / IP Logged
Thank you... ;-)
