1983 cadillac seville vehicle wiring
pinayho24
Member - Posts: 14
Posted: February 07, 2012 at 1:06 PM / IP Logged
hello everyone! i need help!! i am installing a AVITAL 4111 remote start in a 1983 CADILLAC SEVILLE (no model listed on car)..i wonder if the 1984 is the same wiring as 1983 for (remote start ang car stereo wiring)..thank you guys in advance 1983 cadillac seville vehicle wiring - Last Post -- posted image.
es
itsyuk
Silver - Posts: 505
Posted: February 07, 2012 at 2:15 PM / IP Logged
as long far as a remote start goes....probably the same. unless one year is fuel injected ad one year carbed. then there might be a slight difference to do with a tach wire hook up.
the stereo stuff should be the same. when comparing stereo stuff, one being a bose system and one not might need further researching.
hopefully someone will chime in with the schematic you need or give some more info on the situation.
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
pinayho24
Member - Posts: 14
Posted: February 08, 2012 at 1:31 AM / IP Logged
thanks for the quick reply itsyuk..ill  work on this car this weekend..would it be a good idea if  ill use the tachless mode (virtual tach)on this car..thanks again 1983 cadillac seville vehicle wiring - Last Post -- posted image.
es
itsyuk
Silver - Posts: 505
Posted: February 08, 2012 at 2:52 AM / IP Logged
ive seen too many voltage sensing systems keep the starter engaged once in a while. i ALWAYS use a tach wire.
starters and flex plates are too expensive compared to the extra time it takes to run wire needed for a tach wire.
luckily i have not had to do a car that didnt have a tach wire terminal. and i havent done very many cars over the past 4 years.
yuk
Chris Luongo
Platinum - Posts: 3,746
Posted: February 08, 2012 at 7:02 AM / IP Logged
Nice car...I love Cadillacs!
GM wiring colors were pretty standard across the board back then. The wiring for the ignition switch, parking lights, and brake should pretty much all be the same.
The Seville should have pretty much the same wiring right from 1979 through 1985, except for whether or not it has the Bose audio system, as itsyuk said. Also, I think 1984-1985 got the bigger "DIN 1/2" radio from the other GM cars of that era, while your 1983 probably has the separate knobs on each side.
If you're replacing the radio, maybe you can find a dash panel from a 1984-1985 from a salvage yard, and then use that with an aftermarket mounting kit....that way you don't hack up the original dash. Save the original dash (and radio) for the car's next owner.
For the wiring colors, any information from a 1984 Seville should be fine, and I'll bet the DeVille should be pretty close as well, at least for the wiring colors---the cars even have the same steering column.
It's always a given that you'll be properly testing each wire before connecting to it, never rely on a wiring sheet alone. This is especially important when you go to the radio part, because you'll find two yellows, two browns, and I think even two grays in there---it's important to test them for proper function. (Or, hopefully, no one has yet hacked up the factory radio harness---in that case buy a harness for your car instead of damaging it.)
pinayho24
Member - Posts: 14
Posted: February 08, 2012 at 8:24 AM / IP Logged
thanks again itsyuk1983 cadillac seville vehicle wiring - Last Post -- posted image. i really appreciate your taking the time..thanks a lot for your help...@chris thanks for the tip..yep its a nice car like new..wish it was mine..but its my friends car..im going to work on this car this weekend...thanks for the info..again guys! thank u thank u thank u 1983 cadillac seville vehicle wiring - Last Post -- posted image.
es
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
