2007 hyundai sante fe installer
scd2747
Posted: March 27, 2012 at 8:09 PM / IP Logged
I just put a radio in a 2007 sante fe and made the rookie mistake of cycling the ignition with the airbag plug out.. What can I do to clear this code without taking it to the dealer?
Any help would be greatly appreciated
Where did all these left over screws come from?
sparkie
Platinum - Posts: 2,061
Posted: March 27, 2012 at 8:18 PM / IP Logged
You can try disconnecting the negative battery cable for 5 minutes and see if the code will clear/light goes out. Many airbag codes won't unfortunately. The only other thing that may help is to turn the ignition key on for 5 seconds and then turn it off for a couple of seconds. Do this enough times (maybe 40 or more) and the light may go out.
sparky
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
