info needed, door trigger
oldspark
Gold - Posts: 4,913
Posted: March 31, 2012 at 4:08 AM / IP Logged
It can't be a wire at the fusebox, that will always be 12V (unless the fuse is blown).
I presume you have swapped inputs (ie, tried +ve trigger).
Posted: April 01, 2012 at 3:23 AM / IP Logged
Peter it can if there's a processor/timer involved, all Toyotas and VW Golf/Jetta, Fiat Punto Hondas at least, top of my head work this way.
oldspark
Gold - Posts: 4,913
Posted: April 01, 2012 at 7:08 AM / IP Logged
Your experience outranks my theory.
I'd be curious how (unless I misinterpreted) - sensing IMO would have to be current, hence an inserted shunt or loop sensor unless comparing voltage drops between processor +12V and the downstream fuse end.
There are other methods, but I didn't think they'd be used (ie, requiring processors, but since they are now being used, maybe products have finally caught up with "old" methods...?)
Posted: April 01, 2012 at 8:35 AM / IP Logged
I'll email you on this one Peter.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
