progress door and high current wires
Leoayers
Copper - Posts: 73
Posted: March 29, 2012 at 9:14 AM / IP Logged
Installing a viper 5704 on a 07 f150 supercrew want to set the keyless entry up with driver door priority so it unlocks the drivers door first then the rest. also how is the high current wires hooked up? Ive installed older viper alarms never saw the way they want it wired in the worthless manual they include. can anyone help me with the wiring? Thanks for the help
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT
H3/2 RED / WHITE (87) FLEX RELAY +12V INPUT (30A FUSED)
H3/3 ORANGE (+) ACCESSORY OUTPUT
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)
H3/5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL)
H3/6 RED IGNITION 1 +12V INPUT (30A FUSED)
H3/7 PINK/WHITE (30) FLEX RELAY OUTPUT (car side of ign, acc or starter wire)
H3/8 PINK/BLACK (87a) FLEX RELAY INPUT (key side of ign, acc or starter wire if needed)
H3/9 RED / BLACK ACCESSORY/STARTER RELAY +12V INPUT (30A FUSED)
H3/10 NC No Connection
Platinum - Posts: 7,827
Posted: March 29, 2012 at 6:30 PM / IP Logged
        Viper 2007 F150 @ Ignition switch harness
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT                      Dark Blue/Light Green           IGN
H3/2 RED / WHITE  +12V INPUT (30A FUSED)                 Not Used
H3/3 ORANGE (+) ACCESSORY OUTPUT         BLACK/ Light Green     ACC
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE) RED / Light Blue       Cut          Starter
H3/5 GREEN (+) STARTER INPUT (KEY SIDE)   RED / Light Blue       Cut          Starter
H3/6 RED IGNITION 1 +12V INPUT (30A FUSED)             Light GREEN/ Purple       +12V
H3/7 PINK/WHITE  FLEX RELAY          Not Used
H3/8 PINK/BLACK (87a) FLEX RELAY INPUT     Not Used
H3/9 RED / BLACK ACC/STARTER +12V INPUT (30A FUSED)      Light GREEN/ Purple     +12V
Leoayers
Copper - Posts: 73
Posted: March 29, 2012 at 6:52 PM / IP Logged
Thanks so much any idea about the progressive unlock the older vipers had a secondary unlock but cant find that on the 5704
Posted: March 29, 2012 at 7:12 PM / IP Logged
Sorry, can't help with that ( don't even have the 5704 install guide yet ).  Viper is not one of my normal brands, but we do have some very knowledgeable Viper installers / forum members out there...
Leoayers
Copper - Posts: 73
Posted: March 30, 2012 at 11:12 AM / IP Logged
ok I did some research and the 5704 does have a 2nd unlock feature:
(H2/13 wire) 2nd unlock: the wire will operate as 2nd unlock and will not activate for remote control commands.
H2/13 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT
Can someone explain how I wire this up
