backup camera interference
GMC4x4Guy
Copper - Posts: 117
Posted: May 05, 2012 at 12:10 AM / IP Logged
I have a 2008 2500HD Silverado with an Edge Insight and Edge backup camera. I get lines in the screen from interference from the trucks charging system. I did all kinds of troubleshooting and I finally found if I change the cameras power supply to a separate battery (I used a 9V for testing) the problem is gone. Edge sent me an entirely new camera as part of my initial troublshooting so there is no problems at all with any wiring whatsoever and the display didn't change one bit when I installed the new camera and wiring.
The truck starts fine and has no problem charging. The batteries appear to be newer (truck is new to me since September). Is there something simple I can do to "absorb" the interference without jerry rigging a battery just for my camera.
"Drive it like you stole it"
sparkie
Platinum - Posts: 2,061
Posted: May 07, 2012 at 11:21 AM / IP Logged
Make sure that the ground for the components is to the vehicle's chassis and not the truck bed. It could also be the position the cables are routed. Try routing the cables or temporary ones outside the vehicle to see if that helps.
sparky
GMC4x4Guy
Copper - Posts: 117
Posted: May 07, 2012 at 7:54 PM / IP Logged
Thanks. This particular camera has only one ground and it's grounded to the battery.
Platinum - Posts: 13,667
Posted: May 07, 2012 at 8:14 PM / IP Logged
If you power the camera and monitor directly to the battery, is the interference still present?  If not, you may need to use a relay to get a solid power feed to the devices.
Ground the camera to the chassis of the truck as close to the camera as physically possible.
GMC4x4Guy
Copper - Posts: 117
Posted: May 07, 2012 at 11:02 PM / IP Logged
The monitor (gauge) is powered through the OBD-II connector so I can't answer that.
The power/ground/signal is all in one cable from the camera to the front of the truck. There isn't any way to separately ground the camera.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
