1989 honda accord antenna
someone
Posted: May 04, 2003 at 5:27 PM / IP Logged
I have a 1989 honda accord LX 4 dr.
The power antenna unit bent and broke over the winter.
I hhave a manual unit to install, but I cannot get the power mast out of the
a-pillar,
HOW can I get it out of there....??
thanks!
esmith69
Gold - Posts: 1,511
Posted: May 04, 2003 at 6:07 PM / IP Logged
a-pillar? Last time I checked the power antenna motor/assembly was located in the trunk....  There should be retaining nuts/rings on the inside that you must unscrew before being able to remove the assembly.  You'll also have to remove whatever screws are supporting the motor itself--otherwise you won't be able to pull the assembly down far enough to have whatever of the mast remaining clear the body opening.
Ethan
Donate to the12volt.com
