swf relay, type r 200 995
928elan
Posted: May 14, 2012 at 1:08 PM / IP Logged
I've found a relay in my garage that I can't identify. A search of the forum produced no results. Can anyone help please? The make is SWF and the type is R 200 995. It has 5 terminals labelled S, 30, 56, 56a and F. The resistance across the S and 30 terminals is slightly less than 8 ohms. Putting 8v across these produces a click that appears to be non-latching.
If suitable, I'd like to use this SWF relay in conjunction with the headlamp flasher unit on my 1972 Lotus Elan. The Lucas 6RA relay fitted when I bought the car is unsuitable for the flasher circuit, having a coil impedance of approx 60 ohms. This SWF relay would seem to have a coil impedance that might work in conjunction with the standard flasher unit as I'm told the correct relay (now unobtainable) originally fitted by Lotus ahd a coil impedance of approx 4.8 ohms.
However, I need to know which of the terminals 56, 56a and S to connect to what before I blow any fuses!
Thanks in anticipation
Trevor's other car is a Porsche
Posted: May 15, 2012 at 1:30 AM / IP Logged
Appears to be North American, try Googling it.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
