parking lights not flashing python 991
sicivic13
Member - Posts: 26
Posted: June 27, 2012 at 8:08 AM / IP Logged
I just installed a Python 991 to replace the Python 871xp I had in my 2008 Honda Civic Si. Everything is working with the exception of the parking lights. I tapped into the same wires used for the previous alarm. The 871xp had one white wire that was used to tap into the parking light wire. The 991 has 2 wires - the white wire is for the parking light output and the WHITE/ brown wire is for the parking light isolation wire (pin 87a of onboard relay). I tapped the white wire straight into the (+) Parking Light Wire at the fuse box but I have no idea what the WHITE/ brown wire is for. Could anyone please help me resolve this problem?
Thanks,
Steve
sicivic13
Member - Posts: 26
Posted: June 27, 2012 at 9:12 AM / IP Logged
Does the 991 have a jumper to change the polarity for the parking lights?
sicivic13
Member - Posts: 26
Posted: June 27, 2012 at 9:25 AM / IP Logged
The 991 does have an internal jumper for the parking light polarity. I will check to make sure it is set as positive tonight.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
