2012 honda accord door locks
ricardoboston
Copper - Posts: 268
Posted: August 11, 2012 at 7:19 PM / IP Logged
hello everyone  i need please some help to figure out door locks on this car ,if i need to hook up both wires unlock and detection  wires from door lock  to make it work right also any advice for this car thanks
Platinum - Posts: 13,672
Posted: August 11, 2012 at 8:13 PM / IP Logged
Double Pulse to unlock all doors.
     Power Unlock BROWN & WHITE (-) INSIDE DRIVERS DOOR AT KEY CYLINDER HARNESS OR AT MASTER POWER WINDOW SWITCH
     PowerLock ORANGE (-) INSIDE DRIVERS DOOR AT KEY CYLINDER HARNESS OR AT MASTER POWER WINDOW SWITCH
ricardoboston
Copper - Posts: 268
Posted: August 12, 2012 at 2:41 PM / IP Logged
hi sorry for ask it but in order to have  it connected , it need to  have both wires   brown and white  connected to de  unlock wire from the remote start    blue wire, or do i have to use diode ? thanks
Platinum - Posts: 7,787
Posted: August 12, 2012 at 3:33 PM / IP Logged
Diodes required to keep the two vehicle wires isolated.  Here is note from Bulldog Security
NOTE #4: the BROWN (-) is the DOOR Key Cylinder UNLOCK wire and WHITE(-) is the DOOR
UNLOCK Detection wire. Use BOTH wires and Diode Isolate.
ricardoboston
Copper - Posts: 268
Posted: August 12, 2012 at 3:57 PM / IP Logged
thanks guys ,i will try it
