sub box build
20silverado06
Member - Posts: 26
Posted: September 06, 2012 at 12:09 AM / IP Logged
im looking to build a box for my truck to fit 2 12s.i want to try to build a ported downfire box for my silverado ext cab. if i make it ported, does it matter about the airspace anymore. or should i build 2 seperate ported downfire boxes. any help or box blue prints/plans greatly apriciated
DYohn
Platinum - Posts: 10,741
Posted: September 06, 2012 at 11:24 AM / IP Logged
Not sure what you mean by "airspace."  Do you mean the volume inside the enclosure?  If so, it is a critical part of a ported system, much more important than in a sealed system.
20silverado06
Member - Posts: 26
Posted: September 06, 2012 at 1:34 PM / IP Logged
Yea I meant the volume. I have 2 12" q Power deluxes. They run at 1500 watts max a peice(I think around 800 watts rms each) and a 1000 watt mono block comp amp. So should I build 2 desperate boxes or 1 box
DYohn
Posted: September 06, 2012 at 1:39 PM / IP Logged
You can do it either way, whatever you like.  But the size of the enclosure is critical for proper tuning.  What's the model number of your "q-power deluxe" subwoofers?
20silverado06
Member - Posts: 26
Posted: September 06, 2012 at 2:04 PM / IP Logged
this is the only thing i can find bout my subs
http://qpowerinc.com/DELUXEQP12.html
DYohn
Posted: September 06, 2012 at 2:09 PM / IP Logged
Wow, those things look like they will require a pretty huge enclosure... let me run some numbers.
20silverado06
Member - Posts: 26
Posted: September 06, 2012 at 2:14 PM / IP Logged
lol there big. and hit pretty hard to.
DYohn
Posted: September 06, 2012 at 2:18 PM / IP Logged
Yea, a super peaky sub that will bottom out very easily with that kind of power thrown at them, and they require over 300 liters per driver to get anywhere near flat frequency response.  What's the largest size enclosure you can make fit in your vehicle and I'll tell you how to port it.
20silverado06
Member - Posts: 26
Posted: September 06, 2012 at 2:45 PM / IP Logged
well here a little rough copy of a full downfire with my trucks dimensions.sub box build -- posted image.
Hope this helps
DYohn
Posted: September 06, 2012 at 3:12 PM / IP Logged
OK, so that's about a 2.6 cuft enclosure, or about 73.6 liters.  Deduct about 10% for the volume of the woofers and the necessary braces, and you end up with a relatively small 67 liter enclosure.  Put both drivers in it, port it for tuning at 21.7Hz (2" diameter port that is 5" long) and you'll end up with a peaky system but it's the best you can do with those woofers.  You'll also have port noise but I don't think that will matter.  Also, with 800 watts being thrown at the woofers you will bottom them out around 80Hz, so be careful with the volume control and if you hear them making mechanical noises, turn it down.
Page of 3
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
