cs cm6000 negative out
clueless111
Member - Posts: 20
Posted: September 09, 2012 at 12:27 AM / IP Logged
Any suggestions how to get a negative output wire that is triggered BOTH by 1) remote start and 2) manual start (crank/key in ACC position)? Thanks.
Posted: September 09, 2012 at 2:19 AM / IP Logged
The remote start has its own, status or GWR, use a latching relay from the ACC position to answer question 2.
clueless111
Member - Posts: 20
Posted: September 09, 2012 at 4:27 AM / IP Logged
would i need to diode either/both the relay or the status out before I join the two?
Posted: September 09, 2012 at 11:19 AM / IP Logged
Yes "Y" shape going towards upright of the "Y", diode on each arm, diode bands away from upright.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
