door locks
partypeepers
Member - Posts: 24
Posted: September 24, 2012 at 12:22 PM / IP Logged
hELLO I was wondering if anyone knew what relay diagram i should use if im going to be adding aftermarket power door locks and i want to add a switch and also connect it to my keyless entry, (alarm) the alarm has a (-) polarity output so the connections should be for (-) polarity, thank you
cesara
Platinum - Posts: 13,725
Posted: September 24, 2012 at 1:09 PM / IP Logged
partypeepers
Member - Posts: 24
Posted: September 24, 2012 at 1:14 PM / IP Logged
Which one would it be? I tried the 5 wire diagram but nothing happens .
cesara
Posted: September 24, 2012 at 2:07 PM / IP Logged
That link should take you directly to the one you need. It is labeled Actuators / Reverse Polarity.
partypeepers
Member - Posts: 24
Posted: September 24, 2012 at 2:26 PM / IP Logged
Ok found it. but what if I want to add a switch to this diagram? Do I piggy back the wires going to the alarm lock and unlock?
cesara
Posted: September 25, 2012 at 12:51 AM / IP Logged
Yes.
offroadzj
Gold - Posts: 2,043
Posted: September 25, 2012 at 6:14 PM / IP Logged
To lock / unlock by a switch just connect one side of each switch to ground, and the other to the lock / unlock inputs (alarm connections)
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
