type f door lock relay
namkhau
Member - Posts: 8
Posted: September 29, 2012 at 10:00 AM / IP Logged
I just installed the Python 1401 on my car, when I press the unlock button, it's unlock and then lock immediately. sounds like the wire is grounded then opened immediately. maybe the diode doesnt work?
Here is the diagram that I did:
https://www.the12volt.com/12voltimages/1w300d.gif
Posted: September 29, 2012 at 10:07 AM / IP Logged
What car? Some operate in the reverse of that diagram, it shows open circuit lock and ground unlock, yours might be ground to lock and open circuit unlock. TEST.
Posted: September 29, 2012 at 10:10 AM / IP Logged
If I remember Nissans might be the reverse.
Physically test with all doors bar the driver's closed and the catch at the back of the door thrown over, ground the wire with the doors unlocked that should lock, i.e. NEG to lock then cut the wire (RED / yellow on Nissan?) that should unlock.
If it's the reverse it's as the diagram.
namkhau
Member - Posts: 8
Posted: September 29, 2012 at 10:15 AM / IP Logged
it's a 2007 Hyundai Tiburon.
namkhau
Member - Posts: 8
Posted: September 29, 2012 at 10:16 AM / IP Logged
TESTED.
Cut to Lock, Ground to Unlock
Posted: September 29, 2012 at 10:26 AM / IP Logged
Sorry, trying to eliminate the obvious.
Do you have a factory key fob that works correctly and did you copy that diagram to include the diode?
Posted: September 29, 2012 at 10:30 AM / IP Logged
Also disconnect the lock and unlocks, either from the 1401 or at the relay, whichever's easier and try grounding each. If that works the 1401 is at fault.
namkhau
Member - Posts: 8
Posted: September 29, 2012 at 10:32 AM / IP Logged
I don't have the factory key fob and I did exact the same in the diagram.
Im using the Heavy Duty Relay and a 50V 1A Diode
Posted: September 29, 2012 at 12:26 PM / IP Logged
50 volts? Great the EMP generated voltage is about 200!
Use a 1N4004.
Also use a 1N4004 on both lock and unlock wires.
namkhau
Member - Posts: 8
Posted: September 29, 2012 at 12:30 PM / IP Logged
ok. ill run to radioshack and get the 1N4004. Thanks
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
