Posted: October 22, 2012 at 11:41 PM / IP Logged
Posted: October 23, 2012 at 6:17 AM / IP Logged
Posted: October 28, 2012 at 1:37 PM / IP Logged
Posted: October 28, 2012 at 3:19 PM / IP Logged
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Ignition on, Wolo horn activated (factory horn deactivated):
The horn trigger wire will be easiest to access from right near the factory horn, so I will probably do that. The only wire that I really need to find is the ignition wire. Tough finding a solid diagram or layout of the actual locations of the wires. Your descriptions are certainly helpful, though, just need to locate the bundle of wires.
Also, the ignition wire should be easy enough to find once you pull the lower panel off. It's the blue wire and will show 12v (or close to it) in the "On" and "Start" position.
Good Luck! Let me know how it turns out.
