2001 hyundai elantra manula trans
kaira408
Member - Posts: 7
Posted: October 25, 2012 at 12:49 PM / IP Logged
novice here, trying to install a remote starter in my 2001 hyundai elantra,the unit programs but it will not start, it gives 5 flashes and stops what am i doing wrong
lovebird
chev104275
Gold - Posts: 1,436
Posted: October 25, 2012 at 1:24 PM / IP Logged
What system are you installing ? The flashes indicate a code which should be covered in the install guide
kaira408
Member - Posts: 7
Posted: October 25, 2012 at 2:54 PM / IP Logged
i'm using prostart ct3471tw, there is a 5 flash code, 5 fast, the one I got is like counting
lovebird
shortcircuit161
Silver - Posts: 556
Posted: October 25, 2012 at 3:26 PM / IP Logged
According to the Install Manual,
5 Fast Flashes is
New Transmitter learn
Tach learn
Are other functions working? lock/unlock/trunk?
Relearn the tach and make sure you put the system into ready mode and try it again.
Also, to rule out transmitter issues, try triggering the remote starter with the purple external trigger input wire (pin 9 of the 12-pin harness).
Platinum - Posts: 7,827
Posted: October 25, 2012 at 3:28 PM / IP Logged
Here is a link to the CT-3471TW install guide : http://www.engines911.com/asdocs/CT_3471TW_ig_en_h48s40_081014.pdf
Here is the Error Code from Page 25 :
5 Fast         New Transmitter learnt
       Tach learnt
(  Think "learnt" is Canadian for Learned  2001 hyundai elantra manula trans -- posted image.   )
kaira408
Member - Posts: 7
Posted: October 26, 2012 at 12:38 PM / IP Logged
all other functions work,lock, unlock, valet, the 5 flashes I get is like 1/1000,2/1000 and so on. I also tried to put the system in ready mode but it will not go in
lovebird
kaira408
Member - Posts: 7
Posted: October 26, 2012 at 12:54 PM / IP Logged
how do I trigger the remote starter with the external trigger
lovebird
kaira408
Member - Posts: 7
Posted: October 30, 2012 at 1:41 PM / IP Logged
great job frank, it was the tach learning step that was needed to be done.
lovebird
kaira408
Member - Posts: 7
Posted: October 30, 2012 at 1:53 PM / IP Logged
One last question, which is the best wire to use with the horn (lock, unlock, arm, disarm,or one of the aux out wires)
lovebird
shortcircuit161
Silver - Posts: 556
Posted: October 30, 2012 at 2:03 PM / IP Logged
Looking thru the manual that kreg357 linked to above -
Horn Confirmation:
AUX 1 can be programmed to trigger the horn every time the LOCK button is pressed, or when the LOCK
button is pressed twice within 3 seconds. When horn confirmation is activated, panic mode is enabled. If
horn confirmation is disabled, panic mode will not be available.
Mode 3
FUNCTION 2 – AUX 1 Programming
OPTION 1 Horn confirmation upon the 2nd press of the LOCK button
OPTION 2* Priority door access
OPTION 3 Horn confirmation upon the 1st press of the LOCK button
You would use either Option 1 or 3 depending on your personal preference.
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
