acura mdx factory fob with compustar
tae.one
Member - Posts: 13
Posted: November 14, 2012 at 6:09 PM / IP Logged
It was a 2010 Acura TSX, not TL. My mistake.
Platinum - Posts: 7,828
Posted: November 14, 2012 at 6:37 PM / IP Logged
Ahhh, 2010 TSX.  That puts a crimp in the works.  That car is a CAN vehicle and the ADS AL CA flashed with
the HA3 firmware won't work for your MDX.  If it has the TB HA it would.  Check out this install guide to see
if the wiring matches what you currently have ( mostly the 7 Pin connector ).
http://www.idatalink.com/support/get-install-guide/guide_id/10051
No charge for the Door Lock Harness, I have something that will work and it will only cost me a stamp to send.
PM me your address.
tae.one
Member - Posts: 13
Posted: November 16, 2012 at 7:51 PM / IP Logged
Would I be able to use this remote instead of the one I currently have?
http://www./itm/Compustar-RF1WG5900SH-1-Way-4-Button-Car-Alarm-Remote-w-5000-ft-Range-/360512619118?pt=US_Replacement_Remotes&hash=item53f03a026e&vxp=mtr
Which part of the diagram am I comparing. This one?
http://www.fileden.com/files/2006/6/26/90929/ADS-AL%28TB%29%20HA-EN.PNG
Posted: November 17, 2012 at 12:06 AM / IP Logged
Yes, the RF 1WG5900SH will work with the CM6200.  Just get the entire kit.  The kit contains the two remotes, the antenna and the antenna harness,
With the install diagrams, you are trying to determine the firmware that is currently loaded by the actual wiring that was used on the TSX install.  Kinda working backwards, looking for clues like a detective.  If the wires shown on the HA3 install diagram match the wires used, then you can make a good guess what firmware is loaded.
If you have a friendly local install shop that uses iDatalink products and stop by with a dozen doughnuts and the bypass module they might just flash the module with the correct firmware you need for your MDX.  acura mdx factory fob with compustar - Page 2 -- posted image.
tae.one
Member - Posts: 13
Posted: November 17, 2012 at 10:10 AM / IP Logged
I found someone who will flash it for $20. Seems kind of high for a flash. Is this something I can do myself or do I need to buy equipment to do so.
Posted: November 17, 2012 at 10:19 AM / IP Logged
Equipment = ADS USB cable ~$60 plus Dealer access to restricted iDatalink WEB site.
$20 sounds high.  Did you try BestBuy?
tae.one
Member - Posts: 13
Posted: November 17, 2012 at 5:28 PM / IP Logged
I'll check out Best Buy. The harness arrived today. Thanks for that.
