prestige ss9600
ksvista
Member - Posts: 14
Posted: November 17, 2012 at 4:08 PM / IP Logged
Installing a new ss9600 in cadillac srx. I think I've got the basic connections. However, when I press the remote start button 2x's relays click approx 10X's car wont remote start. dispy on remote says inhibit. How can I confirm the flcan is working?
help
ksvista
Member - Posts: 14
Posted: November 17, 2012 at 4:09 PM / IP Logged
2005 cadillac srx
Posted: November 17, 2012 at 5:41 PM / IP Logged
Leave the key in the ignition (off).
If it then succeeds in starting your by-pass either isn't working or incorrectly programmed or needs a flash upgrade.
ksvista
Member - Posts: 14
Posted: November 17, 2012 at 7:28 PM / IP Logged
Still no start with key in the ignition in the off pos.
I've made the following connections and verified
Acc
IGN1
Bat1
Bat2
start
data connection between ss9600 and flcan
OBD connection to flcan
ign+ to flcan
Lock and unlock work fine so I know the data connection works
ksvista
Member - Posts: 14
Posted: November 17, 2012 at 8:59 PM / IP Logged
sorry this is a ss6900. Just need some help I must be missing something
Chris Luongo
Platinum - Posts: 3,746
Posted: November 18, 2012 at 9:12 AM / IP Logged
How do you have the tachometer setting programmed? Default is for tachometer sensing, and the unit won't work until you do something with those settings.
Three choices (this applies to any installation, not just your Cadillac):
1: Connect GREEN/ orange tachometer wire to appropriate wire in car, and go through the "tach learning" routine in the installation manual.
2: Program for "DBI Tach" if the FLCAN guide shows that the unit supplies tach through the data-to-data cable (orange dotted lines)
3: Program for voltage sensing, change the "voltage level" to the non-default setting too. If your car doesn't have a traditional positive-trigger starter wire, also change the Crank Averaging setting to "pre-set time."
If you don't do one of those three things, the parking lights will just flash seven times when you try to activate the remote starter.
Posted: November 18, 2012 at 9:23 AM / IP Logged
Thanks Chris, wondering when (or hoping) you would see this thread.
ksvista
Member - Posts: 14
Posted: November 18, 2012 at 5:16 PM / IP Logged
hey guys thanks for helping a newbe. that did the trick.
Any idea what the color code is for the defrost wire on a 2005 cadillac srx? I checked other forums and could not locate a schematic.
Posted: November 18, 2012 at 5:36 PM / IP Logged
Between rear seat, right hand side and door is the rear loom under carpet edge.
White wire, pulsed (momentary) ground with engine running will trigger it. TEST FIRST and VERIFY.
ksvista
Member - Posts: 14
Posted: November 18, 2012 at 6:26 PM / IP Logged
sorry i should have been more clear. The SRX has dual climate control that resets everytime you start. I've started to probe the wires behind the climate control and can so far only turn the fan on high with a ground. I would like to be able to have the fan on high and the front defrost on.
thanks again!
Page of 3
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
