wiring up a system in a train
robd007
Member - Posts: 25
Posted: December 09, 2012 at 7:45 PM / IP Logged
I've got someone with a train they want a radio with a pa installed.  I'm thinking about installing a basic Pioneer or Kenwood CD player with AUX and a Cobra CB Radio.  I plan on connecting the CB to the AUX.  The train has 4 cars with 3 speakers in each car.  I plan on installing some marine 6.5" in the holes that are already there.  Is there any way to run all 12 speakers without running any amps? That is the part that really has me confused.  Thanks for any help and input.
shortcircuit161
Silver - Posts: 556
Posted: December 09, 2012 at 9:28 PM / IP Logged
It depends on the power output of the headunit and how loud they need the PA to be.   You also want to match the impedance of the speakers to whatever impedance the Pioneer or Kenwood can safely handle (generally 4 ohms).
Since the CB's audio output is mono, you would need a Y adapter that would send that mono audio to both left and right channels equally.
You could then connect each channel of the headunit speaker outputs (FL, FR, RL, RR) to each set of 3 speakers. Again, that may pose a challenge with matching the impedance, but should work great especially if the audio from the PA won't be constant.
robd007
Member - Posts: 25
Posted: December 09, 2012 at 9:50 PM / IP Logged
The impedance is what has me bothered i know the headunit will need to be 4 ohm which i don't know how to achieve. The music and the pa volume will be played at low volumes. I know they make speaker selectors for home receivers to keep the impedance right but don't know of anything like that for car audio.
shortcircuit161
Silver - Posts: 556
Posted: December 09, 2012 at 11:26 PM / IP Logged
You can wire the speakers in sets of 4 using a series/parallel setup.
In this example it shows the impedance at 8 ohms but will work great if the speakers are rated at 4 ohms also since the end result will be one 4 ohm load to the headunit.
wiring up a system in a train -- posted image.
robd007
Member - Posts: 25
Posted: December 10, 2012 at 9:21 AM / IP Logged
Thank you very much for your help Frank.  The speakers are 4 ohm so this will work perfect. I really appreciate everything.
shortcircuit161
Silver - Posts: 556
Posted: December 10, 2012 at 9:37 AM / IP Logged
Glad I could help. Good Luck!
KPierson
Platinum - Posts: 3,527
Posted: December 10, 2012 at 10:05 AM / IP Logged
I know you said you don't want an amp, but I would recommend using a PA amp and running 70V speakers. Find an amp with an input for the Pioneer deck you want to use. You'll have a much more robust system at the end of the day, especially when running all those speakers. If you series/parallel all of those speakers as soon as one speaker goes there will be a domino effect until no speakers work.
Kevin Pierson
DYohn
Moderator - Posts: 10,741
Posted: December 10, 2012 at 10:39 AM / IP Logged
I was about to ask if the train has 120V available. If so, use pro audio gear, not 12V gear.
shortcircuit161
Silver - Posts: 556
Posted: December 10, 2012 at 10:49 AM / IP Logged
Good Point! I didn't think about that.
robd007
Member - Posts: 25
Posted: December 10, 2012 at 11:38 AM / IP Logged
The train only has 12 volt available.  I will look into the PA amp and see what I can find.  If there is an amp with an input, I really won't need a headunit. I could just leave a 3.5mm aux cable for an ipod/mp3 player hookup. Is that right?
Saturday, January 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
